61 - 80 of 106 Posts
Mine was also off by about 1000 miles, meaning battery mileage was lower than ODO.
I never found out why...
What is the problem on your screens? I quickly looked and nothing really popped.
Discussion Starter #62
@twinturboz everything looks good to me, especially the Full Amp Hr, which is almost like new (although I'm not sure about the accuracy of it). Try to measure it after a month or so, and see how it behaves.
Mine also had lower battery mileage, compared to the dash.
What was the dash SOC when you took the snapshot?
My dash was showing 36% and 44 miles remaining.
Just wanted to see my battery health but information overload in there jeez. It’s like a list of ingredients on a itch cream.
Discussion Starter #65
36% dash, 41% something in the battery management system. I get an impression that the battery management system just doesn't let you go below 5 percent physical SOC.
Unfortunately, so far it seems nobody has discovered any way to check HV batt health.
I started a thread for that where my first new idea didn't work, but my second one might, if only a user or two would simply report the voltage at full charge here.
Most users check the bottom of your first screenshot, for Full AmpH, SOH, SOH-R & SOH-C, but yours is a good example of inaccuracy, since it's obviously impossible to have "100%" health after several thousand miles, & even "99.xx%" is highly unlikely
I like to look at what shows on your 4th pic, where your cell voltages are imbalanced by a reasonable 8mV. I've seen mine grow to around 20, but fully charging brings it back to 6.
...Full Amp Hr, which is almost like new (although I'm not sure about the accuracy of it)...
I'm pretty sure the accuracy is extremely low. User reports here show Full AmpH of 64.9 on a brand new car with only 33 miles, and on one with 34,000 miles after 4 years. Another shows only 44.9 after just 16.5k mi.
There is almost certainly a low-end buffer like that, but it seems to me the gauge-vs-OBD difference is just a calibration error on the car's gauge (not OBD showing the % of full capacity).
It definitely doesn't let you go above about 85%. It only charges to 4.1V/cell. That's around 85% of full capacity, but shows "100%" on the car's gauge, & my OBD usually shows around 95-97%
On the low end, I believe "0%" on the gauge is about 2.75V, however I don't yet know what that means in terms of % of true full battery capacity.
Voltage won't tell you the SOH. Voltage under load can give you a better idea. That is why the SOH-R value is important. You can have a crappy battery and it could still show 4.1 volts fully charged. As soon as you put a load on it, the voltage will drop significantly.
When I took my car down to zero (wouldn't move, left the lights and fan on till AlfaOBd said the SOC was zero), the individual cell voltage averaged around 3.1 volts.
THANKS!
Voltage: Right, in general voltage doesn't indicate SOH, but it is related to SOC. The latter was mentioned & my reply to it stands.
HOWEVER, software could allow the max voltage at full charge to gradually increase as the battery ages. That would retain full range for a while, fooling us into thinking we have less degradation than we really do:
Please check this thread & post a reply if/when you can.
I know some electric vehicles do have a way like the Nissan leaf it expands the state of charge in order to look like the same range but I don’t know if the Fiat employs that as I have not seen any other fiats with more than 4.1
Maybe Fiat software fools us by expanding the BOTTOM end:
OBD shows under-voltage warnings start at 2.7V*, leaving quite a bit of capacity below the 3.1V reported by Kiesling as showing at 0%.
Note that 1 volt constitutes 100% of our cars' range, so this extra 0.4V is pretty significant.
Over-voltage warnings start at 4.15V so there's not much capacity to spare there, above the 4.1 we're seeing.
*2.699
How’s it ok to drop volts to 2.7 isn’t that just as harmful as above 4.1? I don’t what’s optimal for a lithium but I’ve seen my secondary Moto Z3 cell phone go from between 2.9v (3%) to 4.4v (100%) Yea I know cell phones are different but they also ain’t thermally controlled either.
Cell phone batteries are very similar physically/chemically, & you're equally well-advised to avoid extremes of SOC or current, but they're much cheaper to replace, even if it means buying a whole new phone.
2.7V might be as harmful as 4.1V. I just relayed the warning activation voltages from OBD. However generally low voltage is apparently less harmful than high voltage. For example, cycling from 10% to 90% is supposedly better than 20-100%. Of course 20-90 is even better.
My point was that even if Fiat isn't fooling us at the top end, they could still be fooling us on the bottom, by gradually lowering the zero % point (where the car stops) from 3.1 to 2.7V, regardless of how much harm that causes, & the subsequent rapid loss of range after that point.
There is a pretty sharp knee in the discharge curve around 3 volts. So going lower than that isn't going to give you much more capacity. I think the 2.7 volt warning is likely used for triggering a flag that something messed up in the BMS or a cell is bad. Pushing 2.7 volts is probably risking damaging the cell.
My guess is Fiat does nothing to trick us one way or another. It is just a compliance car with no warranty on battery capacity or range. I'm sure they just designed the system to minimize the risk of battery damage to increase the chance of reaching the 8 year battery warranty. Limiting the voltage range to ~3.1 to 4.1 volts along with a thermal management system are likely two significant things for reaching this goal. With a small pack, it is what it is. There isn't really room to add an adjustable buffer, protect the battery, and provide a decent range.
It would be interesting to see more data points on average cell voltage at 0% SOC to see if I'm correct.
I'm performing this "0-100" test right now as we speak. I picked up my 2014 500e a few months ago, and while it's been just fine for my daily commuting needs, I've noticed that it definitely seems to be down on range. The most I can really drive it before hitting below 10% indicated soc is about 60mi (97km) with mixed city/hwy driving, usually around 4-4.5 mi/kwh (6.5-7.2 km/kwh).
Unfortunately I do not yet have AlfaOBD to compare the battery SOC values, but I plan on ordering an ELM327 device soon. I just drove the car this morning and got it down to 0% as indicated on the dash (not quite to power limited, but very close). I then let it sit with the fan on full blast, and the rear defroster on for about an hour and a half, while checking the 12v battery periodically to see when the DC/DC would cut off.
Once the DC/DC did finally cut off and stopped charging the 12v battery, I plugged into a L2 EVSE (currently charging at 30a, 208v). I'll post an update when I get more info as to if this makes any difference, and how much power is delivered by the EVSE.
Thanks in advance for reporting back whether or not it makes any difference. Power delivered to EVSE doesn't give an accurate measure of battery capacity, due to things such as heat loss & coolant pump use.
Good job on going BELOW zero % til the DC/DC cut off, since it seems to do nothing if you don't go that far.
Once you get an ELM327 (mine was about $17 on eBay) you can check if it says there's been an SOC adjustment, or if it's "in progress", & also compare the SOC to the car's display (preferably at full, medium, & low SOC).
Discussion Starter #77
Ok, so one important take out is 1.5 hours from 0% on the dash to DC/DC cut off. Good to know.
Please post the ambient temperature and kWh put into charge to 100%.
Discussion Starter #78
If you could do a HV battery data snapshot before U69 and after, it would be awesome.
From the methodology perspective, if you did not charge it to a 100%, the experiment is tainted, as the dash readings could be based on the previous, uncalibrated SOC data.
What is the mileage of your 2014?
Current mileage is just a bit over 56k miles. I certainly wish I could have gotten the full charge in... Perhaps I'll have to try the test again later.
Unfortunately I don't have an ELM327 yet to do a HV snapshot, and I don't think I could get ahold of one before Thursday (unless someone local to North San Diego county has one we could plug in).
Discussion Starter #80
I know it might be a lot to ask the shop, but maybe they could print out the HV data snapshots? Most likely they won't, but who knows.
Total Ah capacity, SOC and cell voltages (both pre and post U69) would be the most interesting to see.
