Under the hood, at the far driver's side, these all have some HVAC function:
40A in slot F08
5A in F09
10A in F19
40A in slot F08
5A in F09
10A in F19
I'm using a $35 battery. It's still going strong after over 2 years.I also take it that I can find a replacement battery for less
$350? They know better, they're scamming you. There is no reprogramming when replacing your 12V battery. If that was a thing- it would have been mentioned in the user manual. Fiat would put that disclaimer for any OEM battery they sell describing the necessary "reprogramming".They are asking for $200 for the battery and another $350 for reprogramming the car for the new battery
Hey all, New to the group and sure this has been asked before, but was not able to find anything. My dealer is suggesting I change the battery in my 2013 500e as it appears to be the original somehow. I am the 3rd owner. They are asking for $200 for the battery and another $350 for reprogramming the car for the new battery. Are they working me on this or what? I have never heard of such a thing, but new to E cars. Any help would be great for those that are more aware of the do's and don'ts on these than I am. Much appreciated Be
Hey all,
Much appreciated
doubt it was the original battery and $200 for the right battery sounds about right but the $350 is bogus. No re-programming of anything was necessary when I replaced the 12v battery myself. Look at a YouTube video.
I would argue lifetime of a battery with you. My daughter's 1997 MB 190 had a still working battery (in California) after 14 years when I replaced it.
- There's no way a 2013 battery would still be good in ANY car, & every mechanic knows that.
- The 500e battery is identical to the gas model, is a standard size used in many other cars, & can be bought at ANY car parts store for as low as $120 at Autozone last time I checked.
- Replacement takes 5 minutes with the right tool: Ratchet, 10" extension, & socket.
- It requires absolutely NO "reprogramming". I've disconnected mine 30 times & it worked fine when I reconnected it.
A fiat 500e puts a lot more strain on a 12v battery than an MGB does.I would argue lifetime of a battery with you. My daughter's 1997 MB 190 had a still working battery (in California) after 14 years when I replaced it.
George
I don't agree with #1. I have 2 2013 vehicles in northern NY that have original batteries and are still solid. Daily drivers. I connect them every two weeks overnight on a charger that doesn't exceed 10% of the capacity. Simple maintenance can save you money over time.
Yes, walk away. If you think the battery is more than a few years old, you might want to replace it. When the battery gets too low (at least in my 2017 fiat 500e) you will get a warning in the dashboard. Change it immediately because after 1 or maybe 2 more starts the car will not allow it to turn on. Search your local auto stores for a new battery and replace it yourself (I did). Just a few simple tools. All my settings remained the same and the clock updated within a few minutes. To help you do it yourself after getting a new battery search YouTube as there probably is a video on there to help you. You could also purchase a voltmeter and check the health of your current battery. Again, search YouTube on tips to do that.Hey all,
Much appreciated
Be
My 500e has smelled "funky wet" after a rain with lots of condensation inside the car and I was wondering how water was getting in. Thanks to you, my leading suspect is the antenna gasket. What do you mean by 1/16" foam?FWIW the antenna replacement sounds about right. Ours started leaking so I pulled it and replaced the foam gasket. To buy a new one was about $100, add an hour of labor and that sounds right.
Or you can do like what I did and buy some 1/16” foam and redo the gasket.
Thanks for that valid info on the lifespan of a 12V battery in an electric vehicle.For those wondering the lifetime of a 12V battery in an EV, it seems to be considerably shorter than the lifetime of that same 12V battery in an ICE car. I belong to several EV forums for different makes of cars. A failing 12V battery is very common in EV cars 3 years old and older. The hypothesis is that EVs never actually have a high current load (like a starter cranking over an engine), so the plates sulfate and eventually short out. Also I have noticed that the DC to DC converter seems to put a high voltage on the 12V system the entire time the car is on, like around 14.4 - 14.6 Volts, which is overcharging the 12V battery and shortening its life span. Also it appears that the 12V battery in an EV will generally fail with little to no warning. You might get lucky with a replace 12V battery now error message. Whereas with an ICE vehicle, you generally know when the 12V battery is failing, as you notice a slow crank.
The cause seems avoidable for a 500e. BatteryUniversity.com seems to be pretty knowledgeable, & they explain how high-current gas engine cranking LOWERS lifespan here, & how HEAT is a pretty big factor. So I shielded the whole side of the battery from the heat of the adjacent onboard charger & then me & several other 500e users had them last over 5 years.lifetime of a 12V battery in an EV, it seems to be considerably shorter
