1 - 14 of 14 Posts
Damping vehicle with secondskin damplifer and closed cell foam. roof, cargo area, inner and outer doors as well as rear panels and trunk lid. The roof really can use it large panel lots of noise.
Discussion Starter · #2 ·
Audison Voce speakers all around. Monstercable speaker wire in-cased in black and blue expandable tube for visual reference. Speaker plates made form PVC copied from OEM speaker.
Built A-pillars for the Audison 3 and Tweeter. Made pod for 3 and tried in many locations as well as different axis to find best position and did the same for tweeter location. This is what worked best. Cut, glassed, filled, and suede to match headliner.
filled in support so fiberglass wont seep into cavity and so mold will come out easily. Made frame no need to fiberglass flat spots. Taped up entire area, test fitted then covered everything before solarezing back of enclosure. then removed mold.
Built mounting ring and wrapped in fleece. Solarezed and then added fiberglass mat for strength. Added hole for emblem as well as filled in areas around seat belt. Filled in imperfections with duraglass as made curved piece on back to match contour when seat is folded down. Then test fitted before wrapping enclosure.
Discussion Starter · #9 ·
Bolted in enclosure using OEM installed bolts as well as sealed with silicone so no air leaks. Filled enclosure with poly fill, and added Abarth emblem and lite up with white leds from behind. Made cover where Factory amp was located and put trunk light in there. And made grill to protect woofer.
1 - 14 of 14 Posts
