2016 500e Dead HV Battery
1213 Views 54 Replies 4 Participants Last post by  Electric Tire Shredder
I've been following posts on the high voltage battery issues. I purchased a 2016 500e from a used car dealer about a month ago. It came without keys. I paid a diagnostic shop to install a new body control module (from the local Fiat dealer) and program two keys. The 12 volt battery was dry of electrolyte, which seemed to indicate a possible drained HV battery. I replaced the 12 volt battery with a new one. When I test the connections in the motor compartment for voltage (under a metal plate secured by three torx screws), I get 5 volts. I've purchased a Chromebook and Konwei plug and downloaded Alfaobd.com. I'm wa
iting for a yellow adapter.
Meanwhile, there's no contactor noise upon turning the key. The dash says "not ready."
Plugging in an OEM 110v charging cord get occasional "goalposts" but no steady charge indication.
I'm hoping to make this nice looking 2016 500e with 56k miles a runner, but so far I'm not hopeful.
I've followed the troubleshooting hints and searched youtube and googled for ideas.
Pleasant suggestions?
21 - 40 of 55 Posts
2
Okay. It might require the contactors to close. Since that's not happening, I wonder if you'd be able to access the contactor enable function in the BPCM:
Product Rectangle Font Line Screenshot
Rectangle Slope Font Line Water
& if you can access it, but it doesn't work, try the contactor tests a little higher up the procedure list in the 2nd pic of the 2nd sequence.
See less See more
Okay. It might require the contactors to close. Since that's not happening, I wonder if you'd be able to access the contactor enable function in the BPCM: View attachment 115434 View attachment 115433 & if you can access it, but it doesn't work, try the contactor tests a little higher up the procedure list in the 2nd pic of the 2nd sequence.
I’m unable to get the OBD Solutions LX101 with Autool yellow adapter to connect.
2
1) Please confirm that you're trying to connect with one of the following:
Airbag
Hands-free
Body computer
Climate control
Instrument panel
Parking
Radio
Tire control
They are the only ones that work with a yellow adapter.
2) Please confirm you're using an OBDLink LX:
Rectangle Packaging and labeling Office supplies Electronic device Font
3) Please confirm the Autool yellow adapter has:
  • Pin 6 on the diagnostic tool end of the adaptor is electrically connected to pin 1 on the car end of the adaptor.
  • Pin 14 on the diagnostic tool end of the adaptor is electrically connected to pin 9 on the car end of the adaptor.
  • Pin 7 on the diagnostic tool end of the adaptor is electrically connected to pin 12 on the car end of the adaptor.
Rectangle Font Parallel Communication Device Pattern
Pic courtesy of @jakjak
See less See more
Airbag
Hands-free
Body computer
Climate control
Instrument panel
Parking
Radio
Tire control
Yes to #1 and #2. For the Autool pins, that photo you attached is too blurry to show where the pins are.
...but it should be in the item description from wherever you bought it.
When I was searching for a Trusted source for "Yellow" OBD adapter I found a few that appeared to be just extensions that happened to be yellow color.
...and after testing this Autool, you're right! It's just an extension (although on eBay it's advertised as an
"extension adapter").
  • Angry
Reactions: 1
These 3 seem to all be good. Prices may be different from the last time I checked:
$11.57 Amazon Yellow Adapter
$11.25 Amazon Yellow Adapter < I got this one & it worked (click here)
$10.99 Amazon Yellow Adapter
Yes, I ordered the middle one earlier today. Thanks!
Reactions: 1
HV Battery SOH-R: 96.86%
HV Battery SOH-C: 79.22%
Does that mean you were able to get the contactors to close?
Still unable to get the contractors to close.
Did you manage to pull the BPCM status log though? Can you post it?
Maximum Battery Cell Voltage: 3680 mV
Minimum Battery Cell Voltage: 3157 mV
Average Battery Cell Voltage: 798 mV
High Voltage Battery Pack Voltage (Bus): 0.00 V
High Voltage Battery Pack Voltage (Pack): 0.00 V
High Voltage Battery Current: 0.00 A
  • Helpful
Reactions: 1
Any chance you could pull all the log file from your Android device, if you have it?
Reactions: 1
8
If you plug the app's device into a computer, the logs can be found by following the "map" here:
Font Screenshot Technology Electronic device Multimedia
The higher mV numbers might be historical, so it would be good if we could confirm the current Max/Min Status, from the logs, or in a shot like this one I took at 0.00% when the car wouldn't close the contactors with the left door or the key, only by plugging in:
Font Number Parallel Document Circle
I there's no digit missing, & there really is a cell at 0798 mV that's WAY too low for the car to allow charging, meaning you'd have to charge the cells individually, after dismantling it as shown below by @vladifresh & then using the method described here by @ATSAaron :
Automotive tail & brake light Vehicle Tire Automotive lighting Automotive tire
Wheel Tire Vehicle Automotive tire Hood
Road surface Asphalt Grass Plant Groundcover
Automotive parking light Tire Wheel Vehicle Car
Tire Motor vehicle Hood Automotive tire Wheel
Flooring Floor Gas Wood Engineering
See less See more
Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297009 Min ECU time stamps (EEPROM): 297006 Min ECU time stamps from KeyOn (RAM): 135 sec ECU time stamps from KeyOn (EEPROM): 30 sec KeyOn counter (EEPROM): 12213 ECU Time first DTC detection (EEPROM): 296895 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 0 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:30:07.073 Faults found. P1E25 P0A1F P1AE2 P167B ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:30:17.730 ___ Tested device: Battery Pack Control Module (BPCM) ___ 2023/05/17 08:30:27.154 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:30:44.864 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:30:47.069 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:45:00.398 Faults found. P1E25 P0A1F P1AE2 P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:45:36.040 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:45:37.431 Faults found. P1E25 P0A1F P1AE2 P167B Faults found. P1E25 P0A1F P1AE2 P167B Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested Error code: P1AE2 Battery Energy Control Module High Voltage System Interlock Circuit Last test completed positively Error intermittent Failure warning lamp 'ON': Not requested Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:46:12.520 Faults found. P1E25 P0A1F P167B ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:46:15.915 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:46:34.040 Faults found. P1E25 P0A1F P167B ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:46:36.030 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:46:37.232 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:46:55.114 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:46:56.430 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:47:12.002 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 08:47:30.699 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:42:07.401 Faults found. P1E25 P0A1F P1AE2 P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:42:32.263 Faults found. P1E25 P0A1F Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:42:41.736 Faults found. P1E25 P0A1F Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:42:53.654 Faults found. P1E25 P0A1F ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:42:57.559 Faults found. P1E25 P0A1F Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:43:12.331 Faults found. P1E25 P0A1F ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:43:13.869 Faults found. P1E25 P0A1F ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:43:15.181 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:43:16.378 Faults found. P1E25 P0A1F Faults found. P1E25 P0A1F Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297048 Min ECU time stamps (EEPROM): 297045 Min ECU time stamps from KeyOn (RAM): 0 sec ECU time stamps from KeyOn (EEPROM): 855 sec KeyOn counter (EEPROM): 12219 ECU Time first DTC detection (EEPROM): 297048 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 0 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:43:54.118 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:43:56.575 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:44:00.837 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:44:10.893 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:44:51.581 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:55:45.921 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:55:58.100 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:56:15.828 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:56:25.051 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:57:06.138 Faults found. P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:57:14.793 Faults found. P0A1F P167B Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:57:23.264 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:57:33.859 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:57:41.479 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:58:09.045 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:58:18.152 Faults found. P0A1F Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:58:27.576 Faults found. P0A1F Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:58:37.951 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:58:39.154 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:58:41.727 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:58:46.121 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 19:59:29.951 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:21:02.793 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:21:13.017 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:21:13.585 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:21:26.622 Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297073 Min ECU time stamps (EEPROM): 297072 Min ECU time stamps from KeyOn (RAM): 30 sec ECU time stamps from KeyOn (EEPROM): 270 sec KeyOn counter (EEPROM): 12258 ECU Time first DTC detection (EEPROM): 297073 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 30 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No Active Diagnostic Status Of ECU: Running in Application mode Gateway: No Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297073 Min ECU time stamps (EEPROM): 297073 Min ECU time stamps from KeyOn (RAM): 0 sec ECU time stamps from KeyOn (EEPROM): 30 sec KeyOn counter (EEPROM): 12260 ECU Time first DTC detection (EEPROM): 297073 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 30 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:23:03.333 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:23:06.068 ___ Tested device: Battery Pack Control Module (BPCM) ___ 2023/05/17 20:32:36.111 DEVICE INFO: Fiat drawing number: 05186015AM VMI: 3C3 VDS: CFFGE1 VIS: GT129785 Hardware number: 0261xxxxxxx Hardware version: 00 Software number: 13.36.09-01 Software version: 3691 Homologation number: 000000 ISO code: 0000000000 SINCOM: Factory: Serial No: VIN - Original: 3C3CFFGE1GT129785 Application Data Fingerprint: 01 34 37 32 31 35 20 20 20 20 19 01 31 ECU Part Number: 05186015AM Boot Software Identification Supplier: Cobasys Number of modules: 01 Module ID: 01 Version Module ID: B.09.03.02 Application Software Supplier: Cobasys Number of modules: 01 Module ID: 01 Version Module ID: B.03.3.09 Application Data Identification Supplier: Cobasys Number of modules: 01 Module ID: 01 Version Module ID: B.xx.xx.xx Boot Software Fingerprint: 01 34 37 32 31 35 20 20 20 20 19 01 31 Application Software Fingerprint: 01 34 37 32 31 35 20 20 20 20 19 01 31 Application Data Fingerprint: 01 34 37 32 31 35 20 20 20 20 19 01 31 ECU Spare Part Number: 05186015AM Ecu Serial Number: ECU Serial Number Data Identifier: T ECU Serial Number Supplier Option: ES ECU Serial Number Component Code: KX ECU Serial Number Day of Year: 273 ECU Serial Number Calendar Year: 5 ECU Serial Number Sequence Number: 00003 Active Diagnostic Status Of ECU: Running in Application mode Gateway: No _ Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297078 Min ECU time stamps (EEPROM): 297077 Min ECU time stamps from KeyOn (RAM): 45 sec ECU time stamps from KeyOn (EEPROM): 15 sec KeyOn counter (EEPROM): 12275 ECU Time first DTC detection (EEPROM): 297073 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 30 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:54:57.569 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:55:10.908 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:55:12.101 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:55:14.709 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:55:23.980 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:58:53.751 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/17 20:58:59.955 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 08:46:56.284 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 08:47:02.029 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 08:47:21.744 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 08:47:58.034 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 08:48:02.498 ___ 'Clear fault codes' command sent Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297113 Min ECU time stamps (EEPROM): 297112 Min ECU time stamps from KeyOn (RAM): 15 sec ECU time stamps from KeyOn (EEPROM): 390 sec KeyOn counter (EEPROM): 12364 ECU Time first DTC detection (EEPROM): 297113 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 15 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Tested device: Battery Pack Control Module (BPCM) ___ 2023/05/18 08:48:23.949 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 08:48:34.111 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 08:48:55.983 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:42:19.764 Faults found. P1E25 P0A1F P1AE2 P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:42:34.488 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:42:45.466 Faults found. P1E25 P0A1F P167B Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:42:57.421 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:43:07.734 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:43:18.624 Faults found. P1E25 P0A1F P167B Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:43:35.385 Faults found. P1E25 P0A1F P167B Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:43:45.429 Faults found. P1E25 P0A1F P167B Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297149 Min ECU time stamps (EEPROM): 297145 Min ECU time stamps from KeyOn (RAM): 165 sec ECU time stamps from KeyOn (EEPROM): 1935 sec KeyOn counter (EEPROM): 12367 ECU Time first DTC detection (EEPROM): 297149 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 150 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:44:11.691 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:44:15.795 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:44:21.986 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/18 15:44:28.817 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:41:35.162 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested Error counter: 200 Test Failed: Yes Test Failed This Monitoring Cycle: Yes Pending DTC Confirmed DTC Test Not Completed This Monitoring Cycle: No Warning Indicator Requested: Yes Environment at first detection: ___ Operating time: 297178 min Time since Key-On: 90 sec Startups counter: 12372 Ignition Status: Run Balance Mode: No Battery Coolant Chiller Valve Position: Open Battery Coolant Heater Valve Position: Open High Voltage Battery State of Charge: 57.65 % Radiator Inlet Temperature: 15 Deg.C battery coolant inlet temp: 17 Deg.C battery coolant outlet temp: 17 Deg.C Maximum Battery Module Temperature: 25 Deg.C Minimum Battery Module Temperature: 25 Deg.C Average Battery Module Temperature: -50 Deg.C Maximum Battery Cell Voltage: 3680 mV Minimum Battery Cell Voltage: 3157 mV Average Battery Cell Voltage: 798 mV Plug in Status: Not plugged in Contactor Closed: Open Battery Contactor Commanded PWM: Not defined High Voltage Battery Pack Voltage (Bus): 0.00 V High Voltage Battery Pack Voltage (Pack): 0.00 V High Voltage Battery Current: 0.00 A Vehicle speed: 0 km/h Battery Cooling Pump Commanded Speed (from BPCM): 0.00 % Battery Heater Commanded Heat (from BPCM): 84.71 % Battery Lifetime AmpHrs of Charge: 44700.10 AH Battery Lifetime AmpHrs of DisCharge: 44087.20 AH Battery Lifetime Miles: 55267.75 miles Battery Isolation Test Status: Run and Passed Powertrain Isolation Test Status: Run and Passed HVIL Test Status: Not Sourced Qualified Contactor Command - QCC: Open Verified Contactor Command - VCC: Invalid HCP Contactor Command: Not defined High Voltage Battery State of Health: 97.65 % Vehicle Isolation Impedance: 2.70 MOhm Battery Isolation Impedance: 6.50 MOhm HV Battery SOH-R: 96.86 % HV Battery SOH-C: 79.22 % Full Amp*H Capacity: 51.70 Ah Max Cell Discharge Impedance: 0.82 MOhm Max Cell Charge Impedance: 50.00 MOhm EEPROM Erase Error: Passed SW running: Failed BCU temperature high: Passed FUSI memory: Failed HWTO: Passed HV HW TurnOff (Layer 2): Passed FUSI - Welded Negative Contactor: Passed FUSI - Current Sensor Loss of Comm: Passed FUSI - Over Current during Charge/Discharge: Passed FUSI - Current Sensor Performance Shunt vs Hall: Passed FUSI - Temperature Sensor Rationality (Bad Reading): Passed FUSI - Pack Over Temperature: Passed FUSI - Pack Under Temperature: Passed FUSI - Temperature Sensor Rationality (Adjacent Modules): Passed FUSI - Cell Voltage Rationality (Bad Reading): Passed FUSI - Pack Voltage Rationality (Bad Reading): Passed FUSI - Cell Over & Under Voltage: Passed FUSI - Module Voltage Rationality: Passed FUSI – Cell Balancing Circuit Stuck ON/CSC Open Line Detection: Passed FUSI - CSC Hardware Performance: Passed EV -WakeUp: Yes Vehicle milage at time of fault: 56114.68 miles System (12) Volts at time of fault: 12.30 V Power Up SOC at time of Fault: 0.00 % Time in Drive, when fault occurred: 90.00 sec Battery in Periodic wake up (Just battery ) at time of Fault: No Battery in Periodic wake up (Wake up vehicle) at time of Fault: No Error counter: 200 Test Failed: Yes Test Failed This Monitoring Cycle: Yes Pending DTC Confirmed DTC Test Not Completed This Monitoring Cycle: No Warning Indicator Requested: Yes Environment at first detection: ___ Operating time: 297178 min Time since Key-On: 90 sec Startups counter: 12372 Ignition Status: Run Balance Mode: No Battery Coolant Chiller Valve Position: Open Battery Coolant Heater Valve Position: Open High Voltage Battery State of Charge: 57.65 % Radiator Inlet Temperature: 15 Deg.C battery coolant inlet temp: 17 Deg.C battery coolant outlet temp: 17 Deg.C Maximum Battery Module Temperature: 25 Deg.C Minimum Battery Module Temperature: 25 Deg.C Average Battery Module Temperature: -50 Deg.C Maximum Battery Cell Voltage: 3680 mV Minimum Battery Cell Voltage: 3157 mV Average Battery Cell Voltage: 798 mV Plug in Status: Not plugged in Contactor Closed: Open Battery Contactor Commanded PWM: Not defined High Voltage Battery Pack Voltage (Bus): 0.00 V High Voltage Battery Pack Voltage (Pack): 0.00 V High Voltage Battery Current: 0.00 A Vehicle speed: 0 km/h Battery Cooling Pump Commanded Speed (from BPCM): 0.00 % Battery Heater Commanded Heat (from BPCM): 84.71 % Battery Lifetime AmpHrs of Charge: 44700.10 AH Battery Lifetime AmpHrs of DisCharge: 44087.20 AH Battery Lifetime Miles: 55267.75 miles Battery Isolation Test Status: Run and Passed Powertrain Isolation Test Status: Run and Passed HVIL Test Status: Not Sourced Qualified Contactor Command - QCC: Open Verified Contactor Command - VCC: Invalid HCP Contactor Command: Not defined High Voltage Battery State of Health: 97.65 % Vehicle Isolation Impedance: 2.70 MOhm Battery Isolation Impedance: 6.50 MOhm HV Battery SOH-R: 96.86 % HV Battery SOH-C: 79.22 % Full Amp*H Capacity: 51.70 Ah Max Cell Discharge Impedance: 0.82 MOhm Max Cell Charge Impedance: 50.00 MOhm EEPROM Erase Error: Passed SW running: Failed BCU temperature high: Passed FUSI memory: Failed HWTO: Passed HV HW TurnOff (Layer 2): Passed FUSI - Welded Negative Contactor: Passed FUSI - Current Sensor Loss of Comm: Passed FUSI - Over Current during Charge/Discharge: Passed FUSI - Current Sensor Performance Shunt vs Hall: Passed FUSI - Temperature Sensor Rationality (Bad Reading): Passed FUSI - Pack Over Temperature: Passed FUSI - Pack Under Temperature: Passed FUSI - Temperature Sensor Rationality (Adjacent Modules): Passed FUSI - Cell Voltage Rationality (Bad Reading): Passed FUSI - Pack Voltage Rationality (Bad Reading): Passed FUSI - Cell Over & Under Voltage: Passed FUSI - Module Voltage Rationality: Passed FUSI – Cell Balancing Circuit Stuck ON/CSC Open Line Detection: Passed FUSI - CSC Hardware Performance: Passed EV -WakeUp: Yes Vehicle milage at time of fault: 56114.68 miles System (12) Volts at time of fault: 12.30 V Power Up SOC at time of Fault: 0.00 % Time in Drive, when fault occurred: 90.00 sec Battery in Periodic wake up (Just battery ) at time of Fault: No Battery in Periodic wake up (Wake up vehicle) at time of Fault: No ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:42:05.323 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:42:17.904 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:42:20.827 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested Error counter: 200 Test Failed: Yes Test Failed This Monitoring Cycle: Yes Pending DTC Confirmed DTC Test Not Completed This Monitoring Cycle: No Warning Indicator Requested: Yes Environment at first detection: ___ Operating time: 297197 min Time since Key-On: 75 sec Startups counter: 12375 Ignition Status: Run Balance Mode: No Battery Coolant Chiller Valve Position: Open Battery Coolant Heater Valve Position: Open High Voltage Battery State of Charge: 57.65 % Radiator Inlet Temperature: 15 Deg.C battery coolant inlet temp: 17 Deg.C battery coolant outlet temp: 17 Deg.C Maximum Battery Module Temperature: 25 Deg.C Minimum Battery Module Temperature: 25 Deg.C Average Battery Module Temperature: -50 Deg.C Maximum Battery Cell Voltage: 3680 mV Minimum Battery Cell Voltage: 3157 mV Average Battery Cell Voltage: 798 mV Plug in Status: Not plugged in Contactor Closed: Open Battery Contactor Commanded PWM: Not defined High Voltage Battery Pack Voltage (Bus): 0.00 V High Voltage Battery Pack Voltage (Pack): 0.00 V High Voltage Battery Current: 0.00 A Vehicle speed: 0 km/h Battery Cooling Pump Commanded Speed (from BPCM): 0.00 % Battery Heater Commanded Heat (from BPCM): 84.71 % Battery Lifetime AmpHrs of Charge: 44700.10 AH Battery Lifetime AmpHrs of DisCharge: 44087.20 AH Battery Lifetime Miles: 55267.75 miles Battery Isolation Test Status: Run and Passed Powertrain Isolation Test Status: Run and Passed HVIL Test Status: Not Sourced Qualified Contactor Command - QCC: Open Verified Contactor Command - VCC: Invalid HCP Contactor Command: Not defined High Voltage Battery State of Health: 97.65 % Vehicle Isolation Impedance: 2.70 MOhm Battery Isolation Impedance: 6.50 MOhm HV Battery SOH-R: 96.86 % HV Battery SOH-C: 79.22 % Full Amp*H Capacity: 51.70 Ah Max Cell Discharge Impedance: 0.82 MOhm Max Cell Charge Impedance: 50.00 MOhm EEPROM Erase Error: Passed SW running: Failed BCU temperature high: Passed FUSI memory: Failed HWTO: Passed HV HW TurnOff (Layer 2): Passed FUSI - Welded Negative Contactor: Passed FUSI - Current Sensor Loss of Comm: Passed FUSI - Over Current during Charge/Discharge: Passed FUSI - Current Sensor Performance Shunt vs Hall: Passed FUSI - Temperature Sensor Rationality (Bad Reading): Passed FUSI - Pack Over Temperature: Passed FUSI - Pack Under Temperature: Passed FUSI - Temperature Sensor Rationality (Adjacent Modules): Passed FUSI - Cell Voltage Rationality (Bad Reading): Passed FUSI - Pack Voltage Rationality (Bad Reading): Passed FUSI - Cell Over & Under Voltage: Passed FUSI - Module Voltage Rationality: Passed FUSI – Cell Balancing Circuit Stuck ON/CSC Open Line Detection: Passed FUSI - CSC Hardware Performance: Passed EV -WakeUp: Yes Vehicle milage at time of fault: 56114.68 miles System (12) Volts at time of fault: 12.20 V Power Up SOC at time of Fault: 0.00 % Time in Drive, when fault occurred: 75.00 sec Battery in Periodic wake up (Just battery ) at time of Fault: No Battery in Periodic wake up (Wake up vehicle) at time of Fault: No Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297199 Min ECU time stamps (EEPROM): 297196 Min ECU time stamps from KeyOn (RAM): 210 sec ECU time stamps from KeyOn (EEPROM): 1125 sec KeyOn counter (EEPROM): 12375 ECU Time first DTC detection (EEPROM): 297197 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 75 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:44:56.132 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:45:01.247 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:45:06.509 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:46:29.386 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:46:30.369 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:46:30.602 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 10:46:30.819 ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 17:05:01.328 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 17:05:13.558 Faults found. P1E25 P0A1F P167B Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 17:05:21.477 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 17:05:31.050 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested Error counter: 200 Test Failed: Yes Test Failed This Monitoring Cycle: Yes Pending DTC Confirmed DTC Test Not Completed This Monitoring Cycle: No Warning Indicator Requested: Yes Environment at first detection: ___ Operating time: 297212 min Time since Key-On: 75 sec Startups counter: 12378 Ignition Status: Run Balance Mode: No Battery Coolant Chiller Valve Position: Open Battery Coolant Heater Valve Position: Open High Voltage Battery State of Charge: 57.65 % Radiator Inlet Temperature: 16 Deg.C battery coolant inlet temp: 17 Deg.C battery coolant outlet temp: 17 Deg.C Maximum Battery Module Temperature: 25 Deg.C Minimum Battery Module Temperature: 25 Deg.C Average Battery Module Temperature: -50 Deg.C Maximum Battery Cell Voltage: 3680 mV Minimum Battery Cell Voltage: 3157 mV Average Battery Cell Voltage: 798 mV Plug in Status: Not plugged in Contactor Closed: Open Battery Contactor Commanded PWM: Not defined High Voltage Battery Pack Voltage (Bus): 0.00 V High Voltage Battery Pack Voltage (Pack): 0.00 V High Voltage Battery Current: 0.00 A Vehicle speed: 0 km/h Battery Cooling Pump Commanded Speed (from BPCM): 0.00 % Battery Heater Commanded Heat (from BPCM): 84.71 % Battery Lifetime AmpHrs of Charge: 44700.10 AH Battery Lifetime AmpHrs of DisCharge: 44087.20 AH Battery Lifetime Miles: 55267.75 miles Battery Isolation Test Status: Run and Passed Powertrain Isolation Test Status: Run and Passed HVIL Test Status: Not Sourced Qualified Contactor Command - QCC: Open Verified Contactor Command - VCC: Invalid HCP Contactor Command: Not defined High Voltage Battery State of Health: 97.65 % Vehicle Isolation Impedance: 2.70 MOhm Battery Isolation Impedance: 6.50 MOhm HV Battery SOH-R: 96.86 % HV Battery SOH-C: 79.22 % Full Amp*H Capacity: 51.70 Ah Max Cell Discharge Impedance: 0.82 MOhm Max Cell Charge Impedance: 50.00 MOhm EEPROM Erase Error: Passed SW running: Failed BCU temperature high: Passed FUSI memory: Failed HWTO: Passed HV HW TurnOff (Layer 2): Passed FUSI - Welded Negative Contactor: Passed FUSI - Current Sensor Loss of Comm: Passed FUSI - Over Current during Charge/Discharge: Passed FUSI - Current Sensor Performance Shunt vs Hall: Passed FUSI - Temperature Sensor Rationality (Bad Reading): Passed FUSI - Pack Over Temperature: Passed FUSI - Pack Under Temperature: Passed FUSI - Temperature Sensor Rationality (Adjacent Modules): Passed FUSI - Cell Voltage Rationality (Bad Reading): Passed FUSI - Pack Voltage Rationality (Bad Reading): Passed FUSI - Cell Over & Under Voltage: Passed FUSI - Module Voltage Rationality: Passed FUSI – Cell Balancing Circuit Stuck ON/CSC Open Line Detection: Passed FUSI - CSC Hardware Performance: Passed EV -WakeUp: Yes Vehicle milage at time of fault: 56114.68 miles System (12) Volts at time of fault: 12.16 V Power Up SOC at time of Fault: 0.00 % Time in Drive, when fault occurred: 75.00 sec Battery in Periodic wake up (Just battery ) at time of Fault: No Battery in Periodic wake up (Wake up vehicle) at time of Fault: No Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297216 Min ECU time stamps (EEPROM): 297211 Min ECU time stamps from KeyOn (RAM): 300 sec ECU time stamps from KeyOn (EEPROM): 15 sec KeyOn counter (EEPROM): 12378 ECU Time first DTC detection (EEPROM): 297212 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 60 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 21:57:03.865 Faults found. P1E25 P0A1F P167B Error code: P167B Controlled System Shutdown Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 21:57:15.322 Faults found. P1E25 P0A1F P167B Error code: P0A1F Battery Energy Control Module Internal Performance Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 21:57:28.742 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 21:57:53.987 Faults found. P1E25 P0A1F P167B Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297218 Min ECU time stamps (EEPROM): 297212 Min ECU time stamps from KeyOn (RAM): 330 sec ECU time stamps from KeyOn (EEPROM): 600 sec KeyOn counter (EEPROM): 12380 ECU Time first DTC detection (EEPROM): 297214 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 90 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 22:18:35.664 Faults found. P1E25 P0A1F P167B Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297235 Min ECU time stamps (EEPROM): 297233 Min ECU time stamps from KeyOn (RAM): 45 sec ECU time stamps from KeyOn (EEPROM): 1230 sec KeyOn counter (EEPROM): 12382 ECU Time first DTC detection (EEPROM): 297214 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 90 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 22:19:33.060 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 22:19:40.205 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 22:19:40.607 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 22:19:48.427 ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/22 22:19:57.131 ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/23 16:45:01.161 Faults found. P1E25 P0A1F P167B Error code: P1E25 Hybrid/EV Battery Failure Level 2 Last test completed unsuccessfully Error present Failure warning lamp 'ON': Requested ___ 'Clear fault codes' command sent ___ 'Clear fault codes' command sent ___ Reading faults for: Battery Pack Control Module (BPCM) ___ Faults reported: 2023/05/23 16:45:16.827 Odometer: 90308.00 km Odometer content to the last F-ROM updating: 0.00 km ECU Time Stamps (RAM): 297247 Min ECU time stamps (EEPROM): 297246 Min ECU time stamps from KeyOn (RAM): 60 sec ECU time stamps from KeyOn (EEPROM): 600 sec KeyOn counter (EEPROM): 12418 ECU Time first DTC detection (EEPROM): 297247 Min ECU Time Stamps from KeyOn first DTC detection (EEPROM): 30 sec Realignment Status: No ProgrammingStatus (EEPROM / FLASH): Boot Block NOT present: No Application Block NOT Present: No Data Block NOT Present: No Transfer Data - Wrong Sequence: No Transfer Data - Incompatible block size: No Routine Control - Erase Memory - Wrong Size: No Routine Control - Erase Memory - Wrong Address: No Routine Control - Checksum - Wrong Address: No Routine Control - Checksum - Wrong Size: No Routine Control - Checksum - Wrong Checksum: No Wrong Sequence - WriteDataByLocal: No Wrong Sequence - Erase: No Wrong Sequence - BlockTransfer: No Wrong Sequence - CheckSum: No Wrong Security Access: No Request Download - Incompatible Area: No Request Download - Incompatible Type: No Request Download - Incompatible Size: No Hardware / Application Software not compatible: No Application Software / Data Application not compatible 1: No
See less See more
Wow, that's a mess. Hope someone can decipher it.
21 - 40 of 55 Posts
