Check all the standard stuff like tires, lights, wipers, locks, windows, etc. but there's no engine, transmission, clutch, fuel pump, timing belt/chain, starter or alternator to worry about, & even the brakes last over 100k since they only activate below 7mph because above that it's all "regenerative" motor-braking.
There are 4 non-standard things to check, all of which are relatively cheap or easy to fix or work around, except this first one:
1) Check for a rare-but-serious weak cell: Get the free AlfaOBD "demo" app* & "Konnwei KW 902" for ~$17 on eBay or ~$30 on Amazon. Click to enlarge:
Scroll down until you see this, without the blue stuff I added:
It should look about like that at full charge, but 20mV difference is fine IF the car's charge is lower, as shown below:
All the rest are usually relatively cheap or easy to fix or work around:
2) See if it charges from the OEM cord AND a "level 2" unit like on a dealer's wall, or test drive to a public station found on plugshare.com
If not, it's sometimes just a temporary minor glitch**.
Use a $9 Amazon "outlet ground tester" to check any outlets you plan to use but note that an extension cord works: 25' max on 14ga, 50' max on 12ga, 100' max on 10ga. Ideally, replace any original 80-cent "residential grade" outlet with a $3.50 "commercial grade" unit.
3) Get $400 off to cover a dealership copy if it doesn't have 2 keys like it came with originally, that each work in the door slot AND start the car with the other one outside (out of transponder range). Work-around: Get cheap copies, tape the OEM one inside the steering column cover, & use the copies to unlock/drive/lock with the door slot, but note the alarm won't arm. That avoids about $1500+towing by preventing the loss of your only transponder key (click here for explanation).
4) Get $1500 off to cover dealership repair if there's a crack or bent pin in the orange part inside the filler flap. DIY is currently $60, as shown in this Facebook vid (click here) using a slightly different part on eBay:
*If you & all your friends only have apple phones/tablets/laptops, the app won't work, but you can search "android smart phone" on Amazon & keep scrolling until you find a cheap one (currently $25). No need for service, just load the app using wifi, & it connects to the car via Bluetooth.
Left 2013. Right 2019.
- Click "shop by category"
- Under "motors" click "parts & accessories"
- Click "car & truck parts & accessories"
- Scroll down & click "electric, hybrid & PHEV specific parts"
- Type "j1772 socket" in the search field & look for this part:
- Check the plug & its orange socket for damage & bent or corroded connectors.
- Deactivate the charge timer in the car’s menu. It can default itself to “active”.
- Turn the car off for 3 minutes & back on.
- Reboot the charger via reset button, unplug/replug, or circuit-breaker off/on.
- Try a different charger.
- Leave the car on when plugging in (necessary if the battery pack is below -14F)
- Hold the button down on the plug until it's fully inserted.
- Try the OEM cord. It can reset some charge errors:
