Ok so very new here. I have searched around to try and get some answers on this, but the common response is 'sell the 500 and buy an Abarth', which is completely valid. However, I'm trying to get some info anyway.
The story is this, I have a damaged Abarth 118kw. It runs and drives perfectly fine with about 50k miles on it. I also have a pretty tired 500 Sport 1.4 NA with 100k miles on it.
So I'm not trying to cobble together all the bits and end up costing me way too much to be worthwhile etc. I have absolutely everything already. I'm not just working out what needs to be done to make it functional.
The idea is to eventually swap absolutely everything I can over from the Abarth, so that effectively I'm just using the main body of the Sport. But there are a few things I'd like to avoid if at all possible, especially if it gets things up and running sooner.
1. Swapping the ECU along with engine I am assuming I need to swap the BCM at the same time. It also looks like I would need to swap the door lock actuators and ignition barrel as well.
2. Do I need to swap the complete wiring harness? Or can I just swap all the things that connect to it? Connectors seem the same, but is there additional wiring that might be in the plugs, or does all the networking mean that the harness is the same?
3. I don't hate the idea of going with the 6 speed. Every post seems to suggest it's not possible, but very little in the way of actual information on it. I'm happy to go with the 5 speed if it's really not an option.
4. How much of the suspension is actually different? We talking shocks and springs here or much more?
5. Is there a difference in the brake booster used?
6. Is there a difference in the power steering used?
7. Are there any other differences that I may not be aware of that might throw a spanner in the works? Things like air conditioning lines etc? Or things like holes in the body for mounting stuff etc?
Sorry to have so many questions in my first post.
