With the car quieter, I noticed the tin backing on the amplifier is buzzing (amp to backing plate). Has anyone fixed the rattle? I'm thinking of a couple dabs of silicone cement will do the job. I'm not sure if high temp silicone will be needed.
I’ve not heard of this. My tail lamps swelled against the fender and I silicone lubed the mounting grommets and it stopped it.
But as for the amp mount, you might try this:
I had a buzzing license plate on a thumper. A small rubber grommet in the two unused lower holes stops it. They don’t touch / press against anything, just hanging off the bracket, but the settle the plate down. Might be worth the effort to even drill a couple few holes if none exist, to try it.
Sorry not seeing how to edit from new. phone the tail light lens squeaked as it rubbed against the fender with the exhausts vibration is what I was meaning. Auto correct put swelled.
Discussion Starter #4 (Edited)
Yes, that might work to take up the extra space, and I could use heat resistant o-rings. Thanks.
The backing plate (heat shield?) behind the amp is a thin sheet of metal and it vibrates against the amp heat sink. With less road noise, I'm hearing little things.
Discussion Starter #5
Thanks, that did the job. The parts house didn't have o-rings, but had plastic washers.
I pulled the 3 10mm heat shield to body nuts. The backing plate is secured w/ 4 torx screws. It has stamped "feet" but that 1/8th" gap turns it into a nice speaker for rattles. I saw a rack of thin 1/4" wide weather strip. 6 strips between amp and heat shield, attach torx, slide washers over the body studs and reattach the nuts. For now, no more rattle.
