1 - 20 of 20 Posts
After my oil change the other day, I looked over the car in the waning sun of September and WHAT?
The rubber at the wing area looks like it is rotting. The driver's side seems to be in better shape, but this has me baffled.
The body shop I use is wondering if birds are pecking at it. Why? We have enough cats around in the neighborhood to keep them on the powerlines.
I haven't seen any cat paw residue on the hood or sunroof.
This side does face East, so the Sun does beat down on it more than the driver's side.
Has anyone in AZ or CA or NV had this show up?
Yes, it's a common fail and cheap to fix. It can be fixed at home in about 15 minutes and Mopar parts are about $17, a couple less on eBay. Even at a body shop, it should be under $100. I think it's just sun, but one guy suggests it is the windshield cleaner.
A couple people have mentioned it needing to be replaced while still under warranty.
Yup, it's most definitely the sun drying up and cracking the cheap Mopar plastic. I have a CA car and I live in SoCal.
I replaced both of mine for $20 on eBay. don't pay a shop to do it! it's very easy.
I guess the price for the pair went up to $30 on eBay but it's still cheaper than getting them from Mopar.
and if you only need one side I think they go for about $14 each on eBay. you might as well replace both though.
Here is the link for the pair.
link for the driver's side.
link for the passenger side.
107978
Before
107979
After
Yeah, had to replace mine too, the drivers side.
FYI, there are two different parts for different trim levels.
There is glossy ones for lounge and matte ones for other trims I think.
my 1957 edition required the glossy one.
The alcohol in windshield washer solvent degrades that rubber. The run off hits exactly that spot. The trim and interior components are also newer lower v.o.c. ref-formulations which dont last as well against the environment. Good idea to rinse off any residual solvent after you’ve had to use them for bug/road grime cleansing of the glass. The alcohol also damages the top strip just fore of the sunroof, if you have one. There is a detail wax from Zymöl that is targeted at protecting the more flexible paint coatings on bumper covers and that top strip. The alcohol in washer solvent and some paint care products is very drying, to paint and rubber.
Yes, thank you KoreanAdian. I forgot to mention that. the glossy trims are also harder to find and a lot more expensive from MOPAR.
True too of course, about the sun adding to or causing this. I overlooked that not all areas use washer fluid with alcohol, but did include environmental in my post. Mine haven’t degraded yet but it is usually parked indoors. Spinning brush type car washes will also contribute to acceleration of the damage.
Before
After
thanks, very usefull!
Has anyone in AZ or CA or NV had this show up? View attachment 107976
Before
After
Thanks so much for the links... mine are both needing replacement. Do you happen to have a link on how to replace? Thanks!
That's the reason why I regularly apply 303 protectant on plastic and rubber trims.
Good point! Regular applications of the right products do help. Door seals should be done annually in most climates, and then, or anytime it is washed/waxed, it would benefit from some protectant.
welcome to the forum @nobken!
here is a youtube video on installing the mirror flags @Corsirs, if you haven’t taken care of it already. I haven't viewed it but it should get you through it fine if it’s the one I’m thinking of.
UNCLE! Guys I’m in Arizona and I noticed the passenger side mirror flag is rotting, I went online to Mopar and they are out of stock and will not have them back for a year. eBay is also a bust, I tried for 2 days to track these down, ordering at online parts dealers and then receiving emails that they also were out of stock. Any ideas?
I’d probably phone some Parts departments in major city fiat dealerships. They part degraded fairly rapidly across the US.
Try Zeigler in Schaumburg Il perhaps. This should be the parts dept for them.
tel:6302462434
Best Wishes!
I have ordered from 5 online parts and all my orders were canceled. Called all the local dealers and the part is not available. If anyone has a lead that'd be great.
That’s it! Thanks so much! Just a quick note those come in two different finishes. My fiat is a lounge model which has a shiny middle panel. The pop finish is matte. Just be careful to get the right ones. 😉. Thanks again!
Exact same problem I have, and yes most online parts places will not have these, ebay is also out of stock for most vendors. I got mine by actually calling dealships to see if they have stock just around. The nice thing about this at least, is that some dealers can check each others stock so you won't necessarily have to call a ton of them.
TLDR. Best bet call locally for stock they have already. Most places are backordered at least 45 days, probably longer.
My car is garage kept and hasn't been driven since 2015. It has 18,000 miles. I had a brain tumor so didn't drive it.
Both my mirror flag trims were always perfect up until last year. The car hasn't left the garage as the fuel pump failed.
Both panels are crumbling now. It was not caused by the sun (since it has been nearly 6 years since it saw any) and I've never used anything but water in the washer.
These trim pieces just degrade over time. They will degrade over time even if new in the box.
1 - 20 of 20 Posts
