Howdy you all I'm hoping someone may have some info for me on what to do. Alright, so I've owned my 2015 E for 1 year and about 3 months ago I was driving 45 and hit the brake and the regen pulsed in and out (never engaged the hydraulic brakes). Then a few weeks later did the same thing doing 25mpg around the neighborhood (once again pulsed and never engaged hydraulic brakes). Then about a month ago doing 75 mph and coming off i25 it did it again and almost crashed because it won't engage the hydraulic brakes. The dash regen says 45kw, 7kw, 39kw, 7 kw, 36kw, 7kw, 29kw then it finally let the hydraulic brakes kick in and I slide through the stop sign. It's like it couldn't tell I was on the brake at all.
So reading around I spent $120 on all new abs sensors and the brake switch under the dash. Then 2 weeks ago I was turning into my drive way and service regen, service abs, lit up and traction control turned off. Sent to a shop in Colorado springs who told me the abs signal for the rear was cutting in and out and the magnetic ring may be bad. So put new SDK hubs on the rear.
Go to pull out of the drive way and the car is stuck in the "idle" phase where it creeps forward. When I push the accelerator I hear the amperage increasing but no acceleration. Plus the service regen is still on and service abs came back on as soon as I hit the brake pedal.
I can rebuild a eco boost motor and an automatic transmission but this electric car has me dumbfounded on what could be wrong and the shop can't look at it again for two weeks. It's been sitting for over a month so far being I can't drive it. Anyone have any knowledge on what could be up? Appreciate any help.
