1 - 20 of 48 Posts
For the last month I've been getting a loud humming from the rear of my car. It's been getting worse. It starts up around 50kmh, is brutally loud by about 80, then quiets down almost completely after 90. I can't tell which side it's coming from, though it is painfully loud over my left shoulder. There is no difference in the tone at all while turning. What I do notice is that when the suspension jiggles over an uneven surface, the humming noise will also fluctuate at the same frequency as the suspension.
I'm running a set of Marangoni winter tires and they're on their last season. The treadwear is even, nothing irregular. I tried swapping my old continentals back on which have about 30000 km of wear and are pretty much done. The sound didn't change. If anything it was louder.
I can try putting my summers with fairly new tires on, but I dont was to expose them to all the salt. And also, is it even worth it? I guess Ill have to call the dealer. Im really getting used to spending my mornings there. I just got the car back yesterday for a slew of warranty work.
I'm bummed out.
When the weight is off the rear wheels is there any side to side shake you can get on the bearing by grabbing 9 and 3 oclock on the tire and pushing back and forth?
Discussion Starter #3 (Edited)
No play at all. Just the piercingly loud hum. Appointment booked for Tuesday.
Of course let us know, maybe they were even too tight? Hopefully isolated instance of whatever is wrong...
I just had a rear wheel bearing replaced under warranty at 5K miles. No noise, but I noticed oil on the brake backing plate signifying a leaking bearing seal. If I hadn't seen that, the bearing would have eventually run dry and start squealing. It's an easy warranty fix, and I would demand that they change both sides.
Take off the wheels in the rear and spin the brake rotor. If it spins endlessly and makes noise it is shot, if it just spins a few times then it is fine.
Here are some videos of my car when I had an issue with wheel bearings.
Good Bearing
Bad Bearing
Discussion Starter #7
As suspected, the rear passenger bearing was shot. I took it to Fiat of Ottawa this morning and luckily they had the part in stock. I was in and out within an hour and now my little guy is rolling nice and quiet. :)
Discussion Starter #12
I feel a need to chime in here. The #1 way to toast your bearings is to run low offset wheels and a lowered suspension without serious camber correction. Not saying it's bad to do, because your car looks awesome, but that's the price you pay for being slammed, or flush--in any car.
Thanks for the update.
I'll plan on repacking mine with a synthetic grease when I do the brake lines, then.
They are not roller bearings with separate seals, but rather ball bearings with integrated shields. Technically the shields could be removed and the bearings re-greased, but I would opt for replacement, as it is a very standard off-the-shelf sealed bearing.
1 - 20 of 48 Posts
