I've had my Fiat since last year as a replacement for my E46. It's been long overdue but finished my headlight retrofit this weekend.
The headlight goods:
-OEM Turbo blacked out headlights
-Koito Bi-LED's
-ZKW-R Clear lens with Honeycomb Etch
-Spaced with 10-24 5/8" bolts and 1/4" nylon spacers
-Body colored passive demon eyes (looks black most of the time though)
Fogs are a direct swap with the Morimoto XB LED Type S fogs
Other goods:
-Hella Supertones
-18% all around with 80% front ceramic tint
-Stubby antenna
-Carbon fiber front trim by emblem
-Trailer hitch
The ZKW-R's etched and you can barely see the passive body colored demon eye
Here are the 1/4" spacers and 5/8" bolts. The extra spacers were to help space the projector to the shroud, but also the top two mounting points between the Fiat and Koito projector are the same! You need to trim the inside of the shroud to fit the new projectors so you can't still use them as bolting points, BUT they make for a perfect visual to make sure the rotation is spot on.
The headlights are permasealed and are a pain, 285 for 17min did the trick with some prying and forcing. Permaseal makes you miss E46 headlights...
Discussion Starter #2
Sorry for the Iphone pics and the thumb in the picture, but carbon mustache update! Next for the front will be the blacked out DRL lights and black Fiat emblem to match the carbon.
