1 - 14 of 14 Posts
Hey folks, I could use some advice on repairing my charging plug. The little spring loaded clip plug broke off. Apparently this triggers a switch inside the car's charging port, so my 500e will no longer charge. It is an Aerovironment unit and they are out of the charger business so I can't get a replacement from them.
Does anyone know if I can buy an aftermarket plug do a DIY replacement?
J1772 replacement plugs are readily available if you search around (Amazon, eBay, Google, etc). They seem to be sold only as complete plugs, not individual parts.
I'm curious however, that since the actual part that broke off is only a plastic hook, does the rest of the spring loaded button lever still move freely and operate normally? If you go through the motion of press the button, insert the plug completely, and release the button, does it still not charge? I feel there must be a way to make the charger think that everything is working normally.
Here's a document that describes what happens electrically with the button (look at the pages labeled "J1772 Proximity"):
I'm not sure how to repair that but you could try a J1772 Extension Cable... there's a few brands on Amazon. Lowest I see is about $132. The extension just clips onto the end of your existing plug and you plug the extension into your car.
Usually I recommend the JLong cables sold in California (link) but at the moment they are sold out. On mine the lever only clips the male and female receptacles together on a top notch... it's not required for operation since it's a tight fit and there are additional levers on the sides that clamp around the edges so it's still locked in-place.
Discussion Starter #6
Thanks. I suppose I could splice this onto the end of my cable. I'm not much of an electrician though. Is it possible to fry my car if I screw up?
Discussion Starter #7
Yes it moves just fine. The only problem is that the L-shaped end part sheared off. I have the piece and could try to re-attach with glue. But what if it breaks off inside the charging port?
Thanks I tried this.
I know right? Gotta be.
What you want to do is try to duplicate what happens at the button on a working plug. Perhaps the button shouldn't be fully released with the plug inserted? The button on your Aerovironment plug seems a different design from most others and I can't compare what happens with mine.
I think you got worn out pins or something I too have used busted up public chargers with missing hook and still charged fine.
Actually the only time I pressed that button was to unhook, usually plugging in I just slide it in and it automatically locks into place.
The question is after plugging in, what is the normal resting position of the button. Is the button fully up or does the plastic piece that broke off cause a displacement that slightly depresses the spring.
Good call about checking the pins. Whatever misalignment that caused the plastic hook to break may have damaged a pin.
Yes .you will have to get creative .unless you want to replace the unit. White some patience you can hand saw from any scrap plastic around you home a copy of the old one. As long as it click the switch in the car port. I did mine out of a abs black plastic piece from home depot in the plumbing dept. Four months and still working fine.
Oops wrong thread
1 - 14 of 14 Posts
