1 - 3 of 3 Posts
· Registered
Hi everyone,
First of all, my apologies, English is not my native language.
I own a fiat 500e since July 2021. I mainly use public chargers, because I don't have a charging station at home. From the day I own the car, this has not always gone smoothly. Sometimes it takes several attempts to connect the car. But for the past few weeks, it hasn't worked at all. The top and bottom lights flash red and the dashboard screen says “check charging system”. If I charge my car with the other cable, via the socket at home, I don't have this problem. So I think (and hope) it has to do with the cable and not with my car. Does anybody else have these problems? And can I just replace the cable if necessary?
Thanks in advance
Steering part Car Motor vehicle Automotive design Steering wheel
Automotive tire Automotive lighting Hood Motor vehicle Automotive design
· Registered
Also see if you can reboot the charging station. Some stations require a reboot every time you plug in. Some stations have a reset button, others reset if you stop & restart the charging process, & others reset themselves 15 minutes after they fail.
Plus make sure your car's own charge timer is deactivated.
1 - 3 of 3 Posts
