1 - 17 of 17 Posts
· Registered
Ok. I've had my Fiat for around 3 months and I've had to take it in 3 times for the following issue. I'll be driving and the car will suddenly shake and all of the warning lights will.come on, check engine is the only one that will stay on. I'm taking it in for the 3rd time. Someone please tell me.that this is a common, easily fixable issue that doesn't need to be taken to the dealership every time. Thank you.
· Registered
Hi Gotmick77,
I understand that you are currently seeking advice from other forum members for this, however, if you are in need of extra support while at the dealer, please feel free to send our team a message.
Darlene
Fiat Cares
· Registered
Hi Gotmick77,
Darlene
Fiat Cares
Darlene, I just want to know why this issue keeps repeating and nobody seems to be able to fix it.
· Registered
Which year/model do you have and how many miles? I'd start by asking the shop what they have fixed on the 3 previous times. If it's not acting up when "repaired", shops (any brand of car) sometimes will just reset the codes and the car sent out as OK. Other times they'll make a guess, based on the codes... even to replacing the same part 2 or more times. With those issues, Fiat Cares can help coordinate a repair, if you are taking it to the dealer.
It would also be a help to run your own scan. Code readers are available for $30, most parts stores can read the codes, and most dealers will share the codes. That won't fix the problem, but it'll give an idea of what the car is reporting.
Yeah, taking the car in is a major PITA.
· Registered
@Gotmick77,
As the Customer Care Team, we are not mechanically trained, however, we can provide additional support while your vehicle is in service at the dealer. We recommend working with your dealer for a diagnosis.
Darlene
Fiat Cares
· Registered
@Gotmick77,
Darlene
Fiat Cares
· Registered
@Gotmick77,
Darlene
Fiat Cares
· Registered
@Gotmick77,
Darlene
Fiat Cares
· Registered
I have a 2015 fiat 500 and it will drive normal and then out of the dash a bunch of indicators come on, ESC, Hill start, Transmission, check engine, etc and the car starts to run rough almost dying *unless I rev the engine, seems like the transmission get stuck in the gear it was running at the time of the errors, cannot shift unless I turn the car off, it shift with a big hit, and back on again. Had all the coil packs & plugs changed, sparks, ECU, brake sensor, still doing the same thing.
· Registered
That is the latest test I had try, I have changed my battery this last week, 2 days were going great, but the faults appears again.
When I mentioned keep revs is to continue moving because the transmission get stuck in 1st or 2nd gear, is not turning turning off.
· Registered
Have you tested your battery? A dying battery will manifest through odd symptoms. Since you state that you have to rev your engine that might be pointing to a bad battery and or a bad alternator.
· Registered
Check engine grounds and battery grounds and under the battery.
1 - 17 of 17 Posts
