1 - 4 of 4 Posts
I have a load noise when I press in my clutch iv taken my car to the dealership 4 times and all they say so far is that (if we take the dash apart toe enspect the noise may be worse when we put it back together ) and they told fiat that there was no noise to be heard. I only know this becouse I made a case about it with fiat. Very frustrated is there anything that any one knows having this same problem and a fix
Have you installed firewall adjuster when the clutch was installed ? If no then, you have to get it installed at the earliest so that the TOB will not contact the pressure plate.Follow this you problem will be solved.
Is it possible for people to practice proper punctuation presently?
1 - 4 of 4 Posts
