I'm not understanding what you mean here, what exactly broke? What connection?The connection between the clutch peddle an clutch has broke.
The connection between the peddle and the push rod to the master cylinder - the plastic fitting jointI'm not understanding what you mean here, what exactly broke? What connection?
I believe the recall had to do with the pressure plates, on early 500 model years. With the manual transmissions. You can contact Fiat care, to confirm.We have a 2012 Abarth with less the 40,000. The connection between the clutch peddle an clutch has broke. Is this a common problem and does it have anything to do with the recall on the early 500s . We have a Prima #189 too.
@tokarevThe connection between the peddle and the push rod to the master cylinder - the plastic fitting joint
