1 - 3 of 3 Posts
Competizione Sport Tuning Lightweight Flywheels are made from one-piece billet steel. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibility of separating from the flywheel. All Competizione Sport Tuning flywheels have passed engineering tests to 12,000 rpm. After professionally installed the flywheel requires a 500 mile break-in period.
Ultra heavy-duty and weighs only 7.8 lbs
Meets or exceeds SFI 1.1 specification
Made from billet steel
Competizione Sport Tuning Lightweight flywheels incorporate special design features to enhance the airflow for improved clutch cooling
Competizione Sport Tuning Lightweight flywheels work with OEM clutch kits
CAD designed, CNC machined and computer balanced
Competizione Lightweight flywheels
OEM
1 - 3 of 3 Posts
