1 - 3 of 3 Posts
My control buttons on the left side of steering wheel stopped working......? For no apparent reason... helpp
Blue & Me problems are very common, where it simply stops communicating. If it's just Bluetooth, you could try using a USB cable (although that's another problem). The first thing you could try is to open the fuse box (left of the steering wheel) and pull the fuses for the radio. I think they are #5 and #10, but the cover will give the correct number. Give it 5 minutes, then plug them back in. That should reset the radio and your phone might renegotiate.
If that doesn't work, there are several threads... some were successful and others not.
In the newer cars, there are odder problems. Mine once reset itself to reading in Italian.
1 - 3 of 3 Posts
