1 - 8 of 8 Posts
Can anyone chime in on this?
I don't see where a camber kit would go in the rear. It's pretty much a shock and a perch. I've only seen camber kits on cars that are IRS.
you can also you a camber plate. to answer your question it depends on how much more you lower your car. if you lower it a lot the stock camber bolts might not have enough adjustment on them to correct it. but lowering it a little you should be fine.
NEED? No. If you really want to dial things in... sure. Go for it - but it's really not a necessity.
1 - 8 of 8 Posts
