If you ever hear a quiet locking beep, or see the 12V warning, start the car from the RIGHT side, BEFORE opening the left door. Worked for me. Can’t hurt to try…:
The $110 500e starter battery can die in just under 2 years. Sometimes the only warning is a quieter locking beep. I heard that, unlocked right away, & got in the left door. That powered up the brake pump (“buzz”), & then it wouldn’t start.
After recharging, the next time it died I unlocked the car right away but got in the RIGHT side so the brake pump wouldn’t activate*. I quickly turned the key all the way & it worked, even though the brake pump came on AT startup (it doesn’t always). After that the drive battery powers everything so it's fine to open the left door.
* You could use the hatch in a pinch.
WARNING! Once your 12V is 22 months old, you SHOULD ensure that you always have a jump available, because may not get a display warning OR a soft beep. For example a loud beep & then the old battery dies while parked for a while.
