1 - 1 of 1 Posts
Hi I am having an issue with my driver window. I searched but can’t find an answer or anything that helps.
So I have a 2012 Fiat Pop. The driver window will not go up, only down. Window regulator works both ways, the switch is good, and I see no breaks in the wiring. I know the regulator is good because i ran power to it and it works both ways. Switch works, I put it on the pass side and it works both ways. I noticed when I push down, the fuse box clicks as it should, but doesn’t click when pushing it up. Idk what else to check. Driving me nuts. Could a relay or something cause this? Thanks for any help.
1 - 1 of 1 Posts
