There's so many special editions of this car coming out that I'm sure at least one of them will be a turbo version. Plus with an engine that small it wont be hard to get the right sized turbo for it.
For the standard 500 1.4 you could start replacing the filter to a BMC or an ITG in place of the paper filter. You will see then on ebay uk. The next is too fit a CAI system - I would recommend an ITG (discussed on a different thread). The manifold is a restrictor on power - this can be changed to a more free flowing one. The CAT is close to the manifold - some had discussed re-locating further down but the best option from what I have been 'told' is to change it to a pukka sports cat - a less restrictive one. There has been quite a discussion in the UK on 95 octance verus V power i.e. 99 octane - quite a few different opinions - but the higher octane seems to increase the bhp although it would be more remarked on a turbo charged engine (an Abarth) with a esseesse ECU or a piggy back chip from TMC. If you turbocharge the standard 1.4 with the 6 speed gearbox - you will have gearbox trouble - it cannot take the extra power of the turbo. The Abarth in the Fiat 500 (A500) uses a 5 speed gearbox from the Alfa 147. I hear that the US are the first to get the multi-air engines to the dissapointment of Europe ! Also the 1.4 multi-air turbo engine has recently won an award for the best engine in the world !
