1 - 3 of 3 Posts
Hi, investigating a new fault on my partners 2013 Fiat 500L. I have a basic code reader which has brought back the following 3 error codes
P0221 - Throttle position (TP) sensor B/accelerator pedal position (APP) Sensor B - Range/performance problem
P1682 - Motorised Throttle
P1687 - Throttle Driven (signal implausible)
question is which sensor is this and where is it located? am I right in thinking it could be the crank sensor on the top of the engine wired into the ignition packs / spark plugs and / or there's a sensor under the accelerator pedal in the cabin...... or something else I'm not considering
There are also 4 warnings on the dash that cycle through when the ignition is turned on
Steering corrector unavailable
ESC unavailable
Hill Holder unavailable
Check Engine
Any help greatly appreciated! Thanks in advance
How old is the battery? First thing I'd do is a battery load test and verify connections are snug especially under the battery tray. That could solve the 4 warnings on the dash when ignition turned on.
Thank you, I'll give the battery a test. as far as I know it's never been changed so that may well sort the dash lights
1 - 3 of 3 Posts
