1 - 3 of 3 Posts
Vendor
Achieve quicker revs on your 1.4L Turbocharged FIAT by switching from your heavy OEM pulley to this lightweight pulley from SILA Concepts.
This pulley is designed to give your turbocharged FIAT a boost in performance by reducing rotating mass of the factory pulley. The stock factory pulley weighs 2.85lbs, the new replacement pulley weighs about a 1/3rd at only .95 lbs.
For the full product details and to get this Lightweight Pulley for your FIAT 1.4L Turbo, please visit the link below:
FIAT Lightweight Pulley - Fits all 1.4L Multi Air Turbo Models (2016+) - 500 MADNESS - Auto Parts and Accessories
Vendor
Discussion Starter #2
This pulley is the same diameter as the OEM pulley, utilizing the original belt layout. Since the crank pulley diameter is unchanged, they maintain alternator output at exactly stock output levels so you need not worry about flat batteries or weak charging capabilities.
To get this Lightweight Pulley for your 1.4L Multi Air Turbo FIAT please visit the link below:
Vendor
Extensive weight savings were afforded by using aircraft aluminum for construction. Power gains are available as a result of this upgrade, but can vary depending on how your FIAT is set up.
We have been using these pulleys on our test vehicles for thousands of trouble free miles. We have also installed these pulleys on several track vehicles as part of our long term evaluations and they have performed without any issues.
For the full details on this Lightweight Pulley for your Turbocharged 1.4L FIAT please visit the link below:
1 - 3 of 3 Posts
