What kind of electrical issues have you had with your Fiat Pop?
  • body control module
    Votes: 0 0.0%
  • fuse panels
    Votes: 0 0.0%
  • wiring
    Votes: 0 0.0%
  • engine
    Votes: 0 0.0%
  • starter
    Votes: 0 0.0%
1 - 1 of 1 Posts
2012 Fiat Pop
Our car has recently needed to be jump started a lot and we thought it was the battery. After several jumps and independent mechanics running diagnostic test, they turned up there is an electrical drain at two points, the BCM at F36 which is the diagnostic socket, car radio, climate control system and at the second fuse panel at F01 which is the body controller. In short, it sounds like either a wiring issue or the car computer itself. If we have to change the wiring harness it can cost around $3000 and we don't know what it would cost for the computer fix.
Anyone else have similar issues with the Fiat 2012?
If so, what was the final diagnosis?
How much did it cost?
1 - 1 of 1 Posts
