Hey, I have a problem because I have a triangle with an exclamation mark on, I don't know what I was at the mechanic for, he checked everything is not happening to me, but the icon is on once it goes out once it is on all the time
If you don't have a CEL (check-engine light) lit, the triangle icon can indicate it's time for an oil change. Are there any messages that scroll across the screen when you start it?
From your owner's manual...
The Generic Warning Light will illuminate if
any of the following conditions occur:
Oil Change Request, Engine Oil Pressure Sensor
Failure, External Light Failure, Fuel Cut-Off Intervention,
Fuel Cut-Off Not Available, Parking Sensor Failure.
Post back so that other's can learn. What was the issue???
Hi. New member here. I have just part exchanged my 2015 500 with 99,000 miles on the clock for a 2017 500 with 20,000 miles on the clock. When it was really hot recently my speedo wouldn't drop below 20 even when I was stationary. When the weather cooled down it was fine. Not sure what I should do if it only goes wrong when it's hot.
