Hello
If ou open the car door then look behind the hinges there is some black squidgy foam filling the gap behind the front wing panel.
However, on my 500 the black 'skin' of the foam has torn and there is white 'marshmallow' popping out, which is getting snagged by the door edge when the door is opened and closed. So when the door is closed there is a bit of foam sticking out of the gap.
Does anyone know if that bit of foam is easy to replace. If the front wing is taken off can the strip of foam be ordered and easy replaced?
Car still under warranty so could get it looked at next service
