1 - 20 of 22 Posts
These photos show the front mud flaps that I installed, using a generic set of flaps obtained at my local auto parts store for $5.18
The size was adjusted using an x-acto knife to a width of 5",
any wider and it will not lie flat against the back wheelwell due to a
small ridge there. Place the flap into the desired location, and rub it against the already installed screws, the resulting marks on the flaps will give you the location for drilling the holes for mounting. Using the already installed
plastic strip, use it after removing, as a template for drilling the necessary mounting holes, using the removed screws. After final mounting, drill a 1/4"
hole in the top of the flap through the wheelwell material, and install a 1/4"
expanding, removable rivit type screw. This is my firs photo posting, I hope it comes out okay.
These look great! I can't tell from the pics but do you have the stock rear mudguards? If so how did the install compare?
Yes, I also have the rear mud flaps from Fiat, and the install was just as easy. On the rear, you have to drill 2 holes per mud flap, and for the front only one (not counting the 3 holes that are drilled thru the flaps themselves).
Thanks for this info, I picked up a set of similar flat mud flaps at Advance Auto Parts, going to try this myself soon.
I didn't realize you don't get a jack unless you get the complete spare tire kit, and I always used the one supplied with my Golf because of the weird pinch weld tabs they have (a regular jack crushes them), so I have to borrow one to do it.
Steve, I'm a little unclear on this. Are you able to use the jack from your Golf on your 500? If so, what year is your Golf? That would be awesome if I could use the one in my wife's Mk VI!
No, I was wondering if the Fiat needed a jack with some kind of special pad or head on it to avoid damaging the body. I looked under there today but couldn't clearly see the location behind the Sport trim piece.
I was just using my old Golf as an example of a car that can't easily use a standard jack.
Sam,
I think what you've done is great. I really want mud flaps on my sport. Am I correct in understanding that you used two existing screws (marked by the rubbing you mentioned) and then one additional screw that went through the plastic wheel well liner?
I would not want to be drilling into metal and exposing it to salt and dirt and water.
I'm going to check in Italy to see if they have mudguards that would fit. I don't recall seeing the sport plastic bit on 500's there and that might be part of the problem here.
But again, very good job.
Discussion Starter · #9 ·
Yes, 2 of the screws I mentioned are hex head, and are visible in photo 4. The top one is a removable rivit type screw that is pushed thru the 1/4" hole drilled in the top of the flap. No holes are drilled into metal, only the fiber wheel well liner. You can see a small plastic piece that is front of the mud flap, that is already on the car, and I kept it as an additional firmness support in front of the mud flap. It was also used as a template for the correct hole spacing when drilling thru the flaps. It would have been easier to describe if I had done a video, but I'm a 63 year old fart, who isn't too up on video techniques. Hope this helps you. I don't think there are any front flaps made for the 500 in europe, although I had seen a post somewhere, where a frnt flap to a Ford Ka was used, and seemed to fit quite well. Good luck.
once the weather breaks, I'm doing something similar too. I think I'll remove the small "spats" for the front wheels (they're useless as mudguards), use them as a pattern to modify a set of generic mudguards. will post my pics whenever I get this done.....sometime this year! LOL :p
where did find out this? Sent from my Argento 500
It seems apparent from multiple posts around forums, short answer, Google. :p But really, it has also been mentioned on this forum above and at another time last year I believe, also other forums and I think several UK owners have used this approach with success as well. ;)
now that youve had them on your car for some time, how well do they work?
i occasionally drive on dirt roads, and sometimes i get mud on my door all the way up to just below the window and also on the back of my rear view mirrors.
would you recommend them being wider or higher up?
View attachment 82203875AB.bmp I found some Mopar Accessory Front Mudguards (PN 82203875AB) that appear to be very close. weather permitting, I plan on working on my 500 this week to see if they will line up. I think if I remove the small "spats" that are on there now, use them as a pattern to trim the Mudguards, they should fit like a glove. we'll see............hopefully good news and pics will soon follow! :)
Discussion Starter · #18 ·
They work very well. As I live about 1/2 mile off the pavement on a dirt road, my car has seen many a mud puddle. It's almost like a little kid, trying to splash itself in every one of them. I have all I can do to steer around them and not give the car it's own way.
Just installed the same mud flaps on my car ;)
Easy installation and perfect fit!
Just wanted to say thanks for this post. I did this modification addition this weekend and am very pleased with the result. Your pictures were a great help.
Jim
1 - 20 of 22 Posts
