41 - 49 of 49 Posts
My old, out-of-service Androids work!
So some friend's old backup one should work too. Or probably you could sign up for a new number & free Android somewhere like Metro or Boost & shut off service after a month. It also may work to buy an unlocked Android & don't even bother hooking it up if you can download the app via wifi.
Sorry for the delay, but I had to give the "free" Android back to Sprint, however I still have my older disconnected Android, was able to download AlfaOBD to it via my new phone's mobile wifi hotspot, & it works fine!
EDIT: Oct 27 I tried an even older (2016) disconnected phone from a service I haven't used since at least 2017, & it also works fine, HOWEVER my 2014 phone would not download the app.
Can anyone shed any light on this, or tell us of something more indicative of SOH to look for?...:
My car shows a somewhat alarming difference between battery cell Block Voltage Sensors (1st pic. 19.45 to 23.37V) even though each individual cell is within 5 MILLIVOLTS (3896 to 3901 mV in 2nd pic, with all subsequent cells within that same range).
Discussion Starter #43
Can anyone shed any light on this, or tell us of something more indicative to look for?...:
The packs have 2 different styles of "modules" inside,
One has 5 cells, one has 6 cells. https://www.ebay.com/itm/18V-64Ah-Fiat-500e-TESTED-Solar-Lithium-Ion-Golf-Cart-battery/223583473849?hash=item340e9d10b9:g:BMkAAOSwRXRZUtfW:sc:FedExHomeDelivery!84107!US!-1
Whew*! THANKS IRON!
So my own batt seems okay with respect to it's low 5mV difference between cells even at only about 50% SOC, after being balanced to 100% a few times recently.
It would still be nice if we could figure out what ELSE to tell prospective buyers to check.
*I wasn't really very concerned, since I still average 1 mile per %, AND still have nearly 2 years of batt warranty left.
Android update: Seems like pretty much any of them will work.
My 2014 LG phone wouldn't download the app via my new phone's mobile hotspot, but it downloaded fine via home wifi, & now OBD works just as well on it as all my other old LGs & my new Samsung.
Unbalancing happened fast:
After only 9 days of not much driving or charging, my cells went from only a 5mV spread to 20mV! (4015 to 4035mV, with 75% on the gauge)
I just checked my records:
Oct 7 I balanced the cells to 100%, at which point there was a 9mV spread.
19 days later the spread was only 5mV.
28 days later (9 days after the 5mV spread) the spread was 20mV, & charging to 100 brought it back to 8mV.
That MIGHT be something to look for (speed of de-balancing), so I'll try to keep track of that to establish a frame of reference, HOWEVER...:
THIS might be more indicative: Every time I look, different cell numbers are the highest & lowest. Any one cell or even any 2 or 3 cells showing consistently high or low would be a bad sign. Anyone testing prior to purchase could check it before driving, charge (preferably to 100) while checking out other stuff, & check again, then check after test-driving, to make sure there are always different cell numbers at the top & bottom of the current voltage range.
All those readings are extremely unreliable. I would take it to my friendly neighborhood metered charger (happens to be Greenlots, but I've seen several metered ChargePoints), preferably at low %, & charge until full. Approximate SOH (as a proportion of new) is charger kWh divided by % charged, then divided by 25.
41 - 49 of 49 Posts
