21 - 23 of 23 Posts
· Registered
"remove the knee airbag" How so? Mechanically unbolt for better access otherwise the knee bag blows?
· Registered
Haha, no, nothing that dramatic. The knee airbag is right in front of the area for access to the upper part of the intermediate shaft. So you just remove a couple of bolts and you can pull the airbag unit out, and disconnect the plug, and you can get your hand into where it needs.
· Registered
Discussion Starter · #23 ·
Finally got my part this week. Your info was great - wheel slightly off center to get access to both bolts.
I notice on my original part it used a 17mm at the bottom, while the replacement used 13mm at both ends, although the shaft of the pinch bolt at the bottom end was wider. Torque spec of 40 ft/lb seemed reasonable but I cranked more than I thought I should have - I actually put one of the old bolts in the old shaft on my workbench and discovered I broke the bolt before getting to the proper torque, so I actually wonder if my torque wrench is on the fritz.
Anyways, all buttoned up and drives nicer with no clunk now.
21 - 23 of 23 Posts
