1 - 1 of 1 Posts
Fiat 500 1.2 2008
Had bumper removed and cooling fan off to replace radiator battery was disconnected Refitted and when started engine the cooling fan is on constant (not when ignition only on) and main beam won’t work but the light on the dash indicates that the switch is and the front dogs won’t light up all thow switch indicates there on. If you power the relays for main beam and fogs they light up Seems odd that all happend from battery disconnect
1 - 1 of 1 Posts
