1 - 4 of 4 Posts
First: This is regarding the home charging with a normal home socket - NOT a chargebox. Please refrain from any comment saying "you are recommended to use a chargebox" or "why don't you install a chargebox". There are good reasons not to at this very moment.
In my garage (Sweden), we are two cars sharing 13A for our two cars. I have a Tesla and I have this Fiat500e. In order not to break the fuse in the garage, we must not together go above 13A.
In the Tesla - it is super easy: the charging current (A) can be restricted from 24A down to 5A, in increments of 1A. This is a visible setting on the charging page.
In the Fiat 500e - in the EV pages, there is something called "levels" marked 1 to 5 to put down the current (A). It is totally unclear what number of A these different "levels" are though! By experience, I have noticed that I have to go for "level 2" not to break the fuse, so that is probably 7A or below.
Now - the Fiat GUI programmers have made it extra unclear, by using "levels" as description in this setting, since "level 2, 3 and 4" ALSO are used within the EV industry describing different types of charging (especially in the US I believe) - see here: https://www.cars.com/articles/what-is-level-1-2-3-charging-437766/ This is something completely different...
PLEASE SOMEONE FROM FIAT READ THIS AND EXPLAIN:
a) What is the current let through to the car on your "level 1, 2, 3, 4 and 5" respectively?
b) Please do CHANGE this in your next software revision so you actually show what current this represents. Today it is super confusing.
NOTHING is referenced to this in your handbook or online. Anywhere. I have searched. And searched. And searched. And asked at my dealership.
2021 Fiat 500e La Prima
I've found level 2 is about 2.5kW. I've never used level 1, nor 3 or 4. Level 5 draws as much as the supplying system can output 7kW at home, 50kW at a charging station.
What i would like is for the FIAT App to be able to select the charging level.
Have you tried emailing the Swedish equivalent of [email protected] ?
In many years of posting on the equivalent AlfaOwner forum, I have never seen any evidence that forum is viewed by Alfa
1 - 4 of 4 Posts
