1 - 11 of 11 Posts
I cant get the under dash fusebox panel open to access the fuses can anyone help I dont want to force it and brake the plastic
Terry
We can't tell you since you a)you didn't introduce yourself and b)it is illegal to circumvent any electronics on this particular vehicle without the express written consent of Jonathan from FiatCares and c) you're from England and this site is dedicated to North American models. You have been warned.
Terry
All I see is a 10mm bolt that can be unscrewed.
you can access the fuses on the NA models without removing anything.
Terry
Terry:
I have posted the first and second charts:
Here is the first one:
1
F12
7.5 Amp Brown
Right Low Beam
2
F32
5 Amp Tan
Front and Rear Ceiling Lights Trunk and Door Courtesy Lights
3
F53
5 Amp Tan
Instrument Panel Node
4
F38
20 Amp Yellow
Central Door Locking
5
F36
10 Amp Red
Diagnostic Socket, Car Radio, Climate Control System
6
F43
20 Amp Yellow
Bi-Directional Washer
7
F48
20 Amp Yellow
Passenger Power Window
8
F13
7.5 Amp Brown
Left Low Beam, Headlamp Leveling
9
F50
7.5 Amp Brown
Airbag
10
F51
5 Amp Tan
Car Radio Switch, Climate Control System, Stop Light, Clutch
11
F37
5 Amp Tan
Stop Light Switch, Instrument Panel Node
12
F49
5 Amp Tan
Exterior Mirror, GPS, Electric Mirror, Parking Sensor
13
F31
5 Amp Tan
Ignition, Climate Control
14
F47
20 Amp Yellow
Driver Power Window
Terry:
1 F12 7.5 Amp Brown Right Low Beam
2 F32 5 Amp Tan Front and Rear Ceiling Lights Trunk and Door Courtesy Lights
3 F53 5 Amp Tan Instrument Panel Node
4 F38 20 Amp Yellow Central Door Locking
5 F36 10 Amp Red Diagnostic Socket, Car Radio, Climate Control System
6 F43 20 Amp Yellow Bi-Directional Washer
7 F48 20 Amp Yellow Passenger Power Window
8 F13 7.5 Amp Brown Left Low Beam, Headlamp Leveling
9 F50 7.5 Amp Brown Airbag
10 F51 5 Amp Tan Car Radio Switch, Climate Control System, Stop Light, Clutch
11 F37 5 Amp Tan Stop Light Switch, Instrument Panel Node
12 F49 5 Amp Tan Exterior Mirror, GPS, Electric Mirror, Parking Sensor
13 F31 5 Amp Tan Ignition, Climate Control
14 F47 20 Amp Yellow Driver Power Window
This one above is the BCM (under the dashboard).. the other one I posted earlier is for under the hood.
There are TWO 10mm bolts that will remove the fuse panel cover. One is open to view, the other is countersunk in to the plastic cover and requires a deep socket drive.
I have looked through three different charts on this site. I am looking for the fuze that controls the Reverse (backup) lights. Anyone have a clue?
1 - 11 of 11 Posts
