ga2500ev
I'm sorry to be Debbie Downer. Yes 12V does come from outside. However, the control of that 12V to the contactors is the BMS, which is inside the battery container. So, again there is no way to control the contactors without having physical access to them.
ga2500ev
No worries, I am happy/thankful that at least people are responding to my questions. This is a great community, and I want to add learning as I have been for other stuff (for some reason this forum also added my google e-mail account as well as my other Vladifresh account, so I have two accounts on this forum now). But, I digressed...
In any case, I much rather cut out a 2-3" access hole in my car floor (and into the cover) than drop the battery (and everything associated with it, including makeshift chargers). There are 2 cables going into the relay circuit. It would be nice to have the pinout of each connector to know where the 12v signal to activate the clunker goes to. I'm willing to guess its the circled one close to the center as the wire gauge is bigger.
I realize that fiat/bosch put those safeguards in place to prevent cell damage, swelling and fire. I am mainly trying to figure out how much voltage I have on my EV battery, which is probably toast anyway (but it can only be checked with the clunker activated, and at the test point location under the hood). Right now the test port is showing me 5.6v, but the clunker is not activated. Additionally, I have the car sitting outside, away from the house or anything that can ignite. Also, if I can get the clunker activated via the 12v signal, I would temporarily leave the BMS signal floating/cut so that the 12v don't go back to it. Also, IF I can get the clunker activated and check the HV battery voltage, I would hook up my factory 110v charge to try and get the voltage up initially, before reconnecting everything back to stock and proceeding forward with the charge.
Assuming that the HV pack will even take the initial charge from my factory charger and not fry it or anything else on the car
