1 - 17 of 17 Posts
· Registered
Smart people of the forum.
How do I unplug this without breaking? This is a HV component connection, there are a few of those under the hood. An older DELPHI model, so I cannot find any documentation.
Motor vehicle Automotive tire Gesture Sleeve Automotive exterior
If I try to pull the white tab, it seems to bend down towards the big orange plug and won't move. Maybe there's a lock hidden somewhere?
· Registered
I did not even touch the second one, I would think this is plastic deterioration or somebody tried something before me, haha.
Anyway, I was told that first you need to unlock and unplug the small black connector and then go through the locks of the orange one. Will try it.
HV connectors are tricky, I can tell you that.
· Registered
Pretty sure the white tab should slide out to enable you to squeeze the orange connector to unplug it. If it does not move, try some contact cleaner spray, it could be just stuck due to dirt, etc. All of these connectors operate approximately the same way: you either squeeze the lock, or slide the tab, or slide and squeeze ;)
· Registered
So the white tab has a lock under the black connector. Once you remove the black connector (pulling out the red tab first), you can press the lock and undo the white tab. The ones I'm doing are muddy so it will take a while, but I will try to post some pics.
· Registered
2013 500e is my only car, since 2015
I'd try a light spray of water, with light scrubbing with a paint brush.
If that didn't work, add a bit of dishwashing detergent to the water & then rinse with pure water.
Before separating any parts, dry well, with a hair dryer on low, if needed.
· Registered
Please do not disconnect any orange connectors unless you disconnect the HV system first. Any wires on the car that are orange or in an orange cover are HV. If you disconnect any of these there is a possibility of high voltage. If you somehow short a circuit, you could DIE! Follow all warnings in the owners manual. Look for how to disable the HV circuit via the HV disconnect.
· Registered
I guess you mean the issue you mentioned in the two threads below, where I failed to ask what happened when you tried the 3 contactor tests (Negative, Positive, & Precharge):
· Registered
Discussion Starter · #17 ·
I did not do the tests, but found that the resistance between HVPDC and the body was below the 200 kOhm limit, which means "vehicle inop", and could be the reason why the contactors would not close (and even if there is another reason, you still need to deal with the LOI first - a LOI should disable everything anyway).
Unplugged the battery heater and the resistance jumped up. So I'm in the process of trying to understand what to do next.
I wonder if the vehicle would get into ready status with a HV component disconnected. I spoke to one shop in our province, and they say "it might or might not". So trying to get more intel on that.
1 - 17 of 17 Posts
