I did a bunch of searching and came to the conclusion that Lasfit LEDs were the ones to try.
And so far so good!
9012 Headlights (Link) LA9012
Its a bit of a tight fit on the passenger side, I recommend taking the bolt out of one of the reservoirs so you can get the headlight cover back on.
Other than that, the wiring just needs to be tucked around the top of where the bulb sits and its done.
Very bright, good beam pattern.
Reverse Lights (Link) L-T15
install exactly like replacement Halogens... No errors, Extremely Bright
Trunk Light (Link) L-T10
This was a test because I wanted to see if these Canbus ready bulbs would actually work on the car. The t10 size is used in a number of places.
Its a bit thick compared to the stock bulb, so it has some issues fitting in the bulb socket. But there is enough flexibility to pry some extra space out of the bulb socket. I'd expect the same issue with the socket on the side markers, and turn signals.
Hope this helps some looking for LED replacements.
i'm going to try out some others as soon as i can. Fogs, interior bulbs, and some side markers.
And so far so good!
