1 - 4 of 4 Posts
How many miles are on your engine? How old is it? Does it only show up after you have a few miles on it, when the oil has warmed up? I hate to say, but it sounds to me like a worn oil pump or maybe worn main bearings... if it has a lot of miles on it.
Oil PRESSURE SWITCH? REPLACED
MULTI AIR VVT? REPLACED
MULTI AIR SOLENOID? REPLACED
OIL CHANGE 5W30 FULL SYN? DONE
HELP!!!!!!!!
96k.
2012500c convertible
As soon as max coolant temp is reached it starts chiming
RESOLVE PENDING....... 5w40 motor oil change.....NOT SYN BLEND OR FULL SYN IS RECOMMENDED.....
Maybe you have low oil pressure.
Just sayin' .... could be like the person above posted, either the oil pump is worn, or worn bearings can cause low oil pressure.
Especially that it comes on once warmed up and at idle, that points to a real problem not just a bad sensor.
1 - 4 of 4 Posts
