1 - 20 of 283 Posts
Hi I have a use 2014 fiat500e and I am getting only about 50 to 55 miles for charge, I noted 5.8 mi/kWh and I don’t understand everybody told me I should get at least 80 miles
2017 Fiat 500e (Billet Argento), 2015 VW Golf Sportwagen TSI 5MT (Tungsten Silver)
Holy, how does one get 5.8 mile a KW that’s like driving slightly downhill all day lol. Best I could get was 5.0mile/kw and that point I get about 103 miles or range. 50-55 mile range is like driving a constant 80mph
I get 5.8 on my key-off "trip summary" after downhill all the way from my grocery store.
The trip gauge gives a much better indication, especially if you never zero it out.
The mile gauge is of course the worst, unless you're driving a fairly constant speed with nearly no hills.
Discussion Starter #6
Outside temperature is about 50 and after I charge it 100% I can go only for 50 miles before I need to charge it again
Sounds like you're having a good ol time then lol. Only way I can get that sort of range is pedal stuck to the floor.
Discussion Starter #8
5.8 is very good. On what numbers are you basing the "50 to 55 miles"?
I set the trip and I can tell that with a full charge I can drive only for 50- 55 miles
No I drive mostly city speed and 60-65 freeway I don’t understand why I get only 50 miles
Okay, so temperature isn't the primary factor. Have you disconnected the humidity sensor?
If you charge to auto-stop, drive 25 miles, & the gauge reads 50%, you're a prime candidate for % gauge recalibration by discharge to zero (drive til it's low, then park by a charger with the heater & lights on).
Discussion Starter #12
Ok. I’ll start over. I just got this car and I was told this car can 80-87 miles with a battery fully charged before having to recharge. What is actually happening is that the car goes up to 50-55 and I then have to recharge it. Is this normal of a 2014 model?
Discussion Starter #14
I’m not sure how to do that. I just got the car.
It's unlikely that the humidity sensor would reduce your range THIS much, but just in case: It's just to the right of the rearview mirror, on the inside of the windshield. Just pop the black cover straight off perpendicular to the windshield surface, then stick a round toothpick in the socket where the purple plug is, & pull that plug out.
Sorry if this seems complicated, but the mileage shown at the bottom of the speedometer is highly inaccurate, & even the % gauge can eventually go out of calibration if you don't take it to zero every half-decade or so.
Discussion Starter #17
How can do the gauge recalibration and the humidity sensor ? I need help please
How can do the... humidity sensor ?
1 - 20 of 283 Posts
