1 - 20 of 29 Posts
Given the poor performance of the stock all season tires during aggressive driving, and the limited selection of 195/45-16 tires out there, do you think it would be ok to move up to a 205 tire? I need a max summer or extreme summer performance tire for street and track.
I know they would look a little more chunky. I've thought about going with a 205/40-16, but I think it would be a bit too small. A 215/40-16 may be too wide for a 6.5" rim.
Has anyone upgraded or thought about upgrading their tires yet?
I'm still learning to drive the 500 fast, but the issue I feel is that the rear end is nowhere as planted as I'd like. It's not bad - it's mostly fun - but sometimes I do feel the rear end trying to go its own way while braking, or while taking a corner at high speed.
My point is - would tires help with this? I feel it's more of a suspension thing than a tire one. Or, perhaps this is because our cars have a really small wheelbase?
It feels frisky, exciting. :p
any pictures Chris?
205/45 would be ok. Your diameter will be a little bigger than with the 195 so your speedo will read a little slower than before. Your overall gearing will be slightly higher.
This is a good thread... I also think the car feels twitchy or unplanted at high speeds and was curious how to make it more stable.
Has anyone who lowered the car with the stock wheels notice any difference? Otherwise, I am going to guess and say wider tires are the solution...
Ed
are you sure it's not the offset vs. the width? Your tires should be wider than your rims even @ 7.5 inches wide.
7.5 inches is 190mm. a 205 tire is about 205mm.
Offset was 35. The rim and tire were both rubbing.
On the wheels I am looking at now offset is 38 but width is 7.
The US version of the 500 has a wider trunk... in the rear even more pronounced on the right side.
perhaps a small spacer will offset the wheel enough to make it work?
That's a bummer though. I guess we're all the test monkeys in this. :cool:
Competizione 17x7.5 match those specs you've listed. All of which say direct bolt on. I guess not eh? Bummer, I liked those wheels.
ooof. Sorry for the formatting. I copied/pasted because I can't spell for ****.
if you are looking to unload those wheels I might be interested. Depending what they are of course.
I thought the original question was if a 205 would fit in the 'stock' rim and work. That would be 205/55/16. Has anyone done this? I will get around to introducing myselt real soon. Just picked up my Pearl sport today.
a 205/55 might fit but that's going to majorly throw off your speedometer. a 55 series tire is what comes on the stock 15 inch and that's only 55% of 185, not 205
1 - 20 of 29 Posts
