1 - 3 of 3 Posts
Hey all, troubleshooting a problem on my daughters 2012 Fiat 500 Pop. Her hatch release wasn't working and I found there was no power getting to the switch. I opened up the wire loom that goes from the top of the hatch to the body. I found that the wire was broken and the bigger wires had the sheathing broken on them. And the wires were worked hardened and some of the strands were broken. I used a crimp connector and it appeared to be fixed. Shortly after it wasn't working again. I probed the wire I repaired and there was no power on the upstream side. At a bit of a loss. Any help would be appreciated. TIA Cheers, Dave
Is this what you fixed? Might have come loose again. Shorted the wires, check your fuses.
110351
1 - 3 of 3 Posts
