Odometer Flashing and phone no longer pairs
1572 Views 10 Replies 5 Participants Last post by  smark
2014 Fiat 500e78,000 mi
My odometer is flashing and my phone no longer pairs.
I've tried battery disconnect.
Removed User Data from Voice interface.
Nothing worked.
I have done a lot of research and I believe it's the module that controls the bluetooth.
I've heard it called the CAN module or telematics module.
I have read that a CAN proxy reset might correct the issue. If that fails then its most likely the module.
I am guessing you need a good odbc reader to the proxy reset job. Don't know?
Also, if you replace the module you may also have to do a proxy reset.
Anyone here no where the module is located. I saw a video where it was behind the passenger seat in the back wall panel. However, that was a euro version car. Would like to know left or right?
Any comments or suggestions would be helpful.
1 - 11 of 11 Posts
The only cure I'd seen for flashing odometer was proxy alignment, until I saw this recently:
Reactions: 1
UPDATE: Hack in post #2 above has failed in 2 out of 3 cases:
  1. @deftoner reported that it worked.
  2. It didn't work for the next owner reporting. I think it was @Brettucks
  3. It didn't work for me. I disconnected the left light, turned the car on, pressed the brake, got the bulb warning, reconnected, warning gone, odometer still flashing. I repeated on the right, also with no luck.
Hello Fiat500eMan14 - Did this fix work for you?
My Fiat 500e with about 42K miles has a flashing odometer and no radio. Everything else seems to be okay - charging, lights, etc. Any update on your 500e problem is appreciated. Thanks
Nothing worked.
I have the same issue no phone and flashing odo. Dealer says telemetrics module is bad and a replacement is around $1000. At that price I will live with it as the car already has 95K miles on it and the range has deteriorated severly.
Range based on the car's % gauge?...:
I have subsequently learned that when the odometer is flashing it can make the % gauge jump up while charging, & subsequently plummet when driving, making the car die on the road. Please see item 6 here:
You blue tooth module might be defected. It resides behind the glove box.. If you own a European 500.
it’s behind the left hand side rear side panel.
Check out Love 500, on YouTube. He’s replace a couple of them.
Good Luck.
1 - 11 of 11 Posts
