1 - 20 of 43 Posts
The paint on your wheel certainly shouldn't be peeling already. I would think that would fall under "manufacturers defect" provided that there has been no impact.
If it is not due to impact and just cropped up out of nowhere - I can't imagine that it's not covered! Definately check with your dealer on that issue - if they don't bend willingly shoot a PM to FiatCares. I'm sure it will be resolved.
I think you have a case for the wheel - the slear coat should not look like that already. As for stone chip... well if you call it a stone chip they surely won't do anything.
Sorry rock chip aren't covered under warranty. I have a few too. I try to keep my distance while on the Highway. Touch up paint, alway make it look worst too. Try not to tail gate people. The clear coat on the wheel looks like a different situation. Why would they peel, unless a rock hit it too!
My wheels, on a couple my new Honda's peeled like that. Honda replace them. Honda's good about those things. After the warranty was over, they started to peel again. See what Fiat says. If the clear coat peels off the aluminum the wheel will start to corrode.
I've used Langka Paint Chip repair kit on my Audi with good results and it's a pearl blue/gray. I also found two chips on my hood, above the 3M clear film. I ordered the paint and will try in a few weeks, then get the whole hood redone in clear vinyl.
what's best
way to fix a stone chip?
the stone chips are on the bonnet and door don't think u can call much more
or less what they are. i see some kits
online that show some good results.
Anybody have
any experience fixing these lil buggers
call it a paint chip because stone chips arent covered under warranty.
as for how to fix it, take it to a bodyshop and have them do it the right way.
i would never use touch up paint on my car simply because its ghetto and most times i can still tell where the paint chip was beforehand.
also touch up paint doesnt provide proper corrosion resistance so keep that in mind if you plan on keeping your 500 for some time.
1 - 20 of 43 Posts
