Hey guys! Back again with another projector fog light retrofit. This one should be pretty easy to replicate as all the parts are readily available.
We start with a pair of Ford Fusion projector fog lights. You can find these on ebay, and here. These are absolutely fantastic fog lights. Sealed and ready to go for outside use. No need to put them in a housing, they are good on their own. They also take HID bulbs remarkably well.
Here they are in stock form:
IMG_20130110_010200_zps76b14621 by gnrfan228, on Flickr
And after the mounting bracket is removed on the left. The right one had the mounting bracket and some material removed, but not nearly enough.
WP_20140305_001 by gnrfan228, on Flickr
And finally the projector fully modified along with the L bracket used to mount it to the adapter plate. The L bracket is attached to the projector with one 1/4" bolt which is secured with a lock nut. It's not coming loose! After I ground off all of the aluminium from the sides, I repainted the light with high temp black caliper paint to cover the bare aluminium.
WP_20140317_004 by gnrfan228, on Flickr
WP_20140317_005 by gnrfan228, on Flickr
And here's one of the adapter plates used to attach it to the bumper using the stock bolts. The blue holes are for attaching the L bracket on the projector. The red squares are for bolting it to the body. I made them large squares in order to give me some adjustment in rotation, vertically and horizontally. You don't have a whole lot of room to move though, but thankfully you don't need much.
WP_20140317_006 by gnrfan228, on Flickr
You do also have to modify the bezel that covers the fog lights. Just grind down the opening of the bezel to make more room for the light, as it sticks out quite a bit.
WP_20140317_009 by gnrfan228, on Flickr
WP_20140317_010 by gnrfan228, on Flickr
WP_20140317_011 by gnrfan228, on Flickr
WP_20140317_012 by gnrfan228, on Flickr
WP_20140317_014 by gnrfan228, on Flickr
WP_20140317_013 by gnrfan228, on Flickr
Let me know if you have any questions!
Thanks tweak!
I'll try to get some output pictures uploaded in the next week or two. Work is kicking my butt right now.
