Hi. Happy new year to all.
Our 2015 Fiat Lounge has 82,000 kms on it. We bought it last summer. It is in very good shape and running great. It seems to have been quite well maintained. We want to keep it for a long time. We will use it as a summer only car. It will be kept in a heated garage each winter.
I have have it sprayed with rustproofing. Winter storage will consist of filling with premium non-ethanol fuel, adding fuel stabilizer and filling tire to proper pressure. I will also start it every 2 weeks and bring it up to operating temperature to maintain oil pressure in brick.
I know the spark plugs were changed at around 65,000 and I have confirmed no leaks under PVC valve housing.
I reviewed all the maintenance history and have not found any record of the following being done. Here is want I plan to get done on the car in the spring.
Any advice, comments or other recommendations would be appreciated.
Thanks
- Oil and filter change. Synthetic oil.
- Have Automatic transmission fluid changed. I was just going to get them to just do a drain and fill. Not a transmission flush. I know that will not change all the fluid. I am worried that doing a true flush may do more harm than good.
- Have coolant system flushed.
- Have brake fluid flushed.
- Clean or change the Multi air filter on side of engine (Behind timing belt cover)
Thanks
