I just bought Vogtland lowering springs but have not yet had them installed.
Will I be able to run 205/50x16 without clearance or rubbing issues?
I've also considered 205/40x16...
(Wheels are OEM offset/backspacing; 6.5 rim width)
2013 fiat 500 pop
I like to know your year model of 500, I'm thinking on taller tires for my 2013 pop with OEM steel wheels, ty
You should not have any rubbing issues. I think your wheels are ET35 and only 6.5 inch wide. You can go 205/45-16 or use the size you have.
I lowered mine 2.5-inch front and rear running 17X7.5 ET20 on 205/40-17
Discussion Starter #5
My wheels are 16x6.5 inch Magneti Marelli (the "black stain" ones from 500 Madness).
They are essentially a direct bolt-on replacement for the OEM optional alloy wheels... same diameter / width / offset / backspacing.
Thanks for the feedback...
