1 - 11 of 11 Posts
A couple of questions, Will ..
1) Everything I have read so far about doing an oil change indicates that you have to pull the bottom plastic "pan" to drain the oil. Can you do that with the bottom brace in place, or do you have to remove the brace to pull the plastic pan?
2) Can the "multiair" plastic engine cover remain in place with the top bar in place, or do they compete for the same space?
Thanks!
John
Thanks!
John
Hi John
1) You can removed the bottom plastic with out removing the brace.
2) yes the "multiair" engine cover can go back on! it will clear the top brace.
1 - 11 of 11 Posts
