1 - 11 of 11 Posts
I have a 2013 Fiat 500 Pop that is leaking transmission fluid. We bought it used and whoever had it previously had cracked and “repaired” the bell housing. The drain plug has been compromised and there is no way to tell how much ATF is in it. It’s not leaking real bad yet but I need to know how to put fluid in it. I was told the filler tube is under the battery box...it is not. Can someone please tell me where it is? Thanks in advance.
Thanks! We finally found the fill. Now to figure out what will get it out. A 50 torx too small and the 55 was too big.
Nice! Did you pick up the dipstick? They are reasonably priced and even available on Amazon. Considering they have markings for 2 temps, I wonder if a temp gun would be needed.
You don't need one for the manual. Like most manuals, you just fill until oil comes out the fill hole.
1 - 11 of 11 Posts
