1 - 15 of 15 Posts
Any TSB's on the leaky coolant reservoir issue?
I've hose clamped mine... but still lose coolant.
Thanks!
-Ryan
Hello RyanR,
Might not be the hot bottle. I was loosing coolant and turned out to be the water pump going out. Havn't lost much since (except for the normal amount that usually evaporates out when pushing the engine hard).
Thanks!
-Ryan
If I can locate a TSB I'll share but I do know both the hose and in some cases the reservoir itself (cracks/breaks) have been an issue for some.
I noticed some dried up coolant sitting on top of my reservoir recently as well as the coolant being a little low. I'll bring it up to the dealer at my next oil change, in the meantime, I'll keep an eye on it.
2012 Fiat 500 Recalls
I tried to upload the recalls in PDF, but they exceed the 19.5 KB file size limit. Here is a short overview of recalls that I found:
Technical Service Bulleting (TSB) Description
Source Type
TSB #
Issue Date
Type
Diagnostic Link Connector - DLC, Cover Must Be Removed From U.S. ...
OE
08-056-11
10/5/2011
Technical, Recall, DealerNotification, Warranty, Labor
Click And/Or Clunk Near A-Pillar While Opening Doors
OE
23-038-11 REV. A
12/2/2011
Emissions Recall M03 - Diagnostic Link Connector Cover
OE
RC-M03-12
3/1/2012
Safety Recall L39 - Brake Fluid Contamination - STOP SALE ORDER
OE
RC-L39-12
2/1/2012
Technical, Recall, Warranty, Labor
SAFETY RECALL L39 - CONTAMINATED BRAKE FLUID
OE
RC-CL39-12
3/6/2012
Customer Satisfaction Notification M29 - Windscreen
OE
RC-M29-12
12/1/2012
Customer Satisfaction Notification M32 - Reprogram Powertrain Con...
OE
RC-M32-12
9/1/2012
OE
RC-IM32-12
9/1/2012
CUSTOMER SATISFACTION NOTIFICATION M29 - WINDSCREEN
OE
RC-CM29-12
12/1/2012
CUSTOMER SATISFACTION NOTIFICATION M32 -REPROGRAM THE POWERTRAIN ...
OE
RC-CM32-12
9/1/2012
Customer Satisfaction Notification M20 - Engine Coolant Hot Bottl...
OE
RC-M20-12
10/1/2012
CUSTOMER SATISFACTION NOTIFICATION M20 - ENGINE COOLANT HOT BOTTL...
OE
RC-CM20-12
10/1/2012
Customer Satisfaction Notification N15 - Starter Motor Mounting B...
OE
RC-N15-13
4/1/2013
OE
RC-IN15-13
4/1/2013
CUSTOMER SATISFACTION NOTIFICATION N15 - STARTER MOTOR MOUNTING B...
OE
RC-CN15-13
4/1/2013
2013 Fiat 500 Recalls
Source Type
TSB #
Issue Date
Type
Emissions Recall N09 - Reprogram Powertrain Control Module
OE​
RC-N09-13​
2/1/2013​
EMISSIONS RECALL N09 - REPROGRAM POWERTRAIN CONTROL MODULE
OE​
RC-CN09-13​
2/1/2013​
Safety Recall N51/NHTSA 13V-358 Halfshaft-to-Gearbox Output Flang...
OE​
RC-N51-13​
8/1/2013​
2014 Fiat 500 Recalls
2014 Fiat 500L recalls: *no recalls were noted for other models
Source Type
TSB #
Issue Date
Type
Safety Recall P06 - Automatic Transaxle Gear Shift Module
OE
RC-P06-14
3/1/2014
Recall
SAFETY RECALL P06 - AUTOMATIC TRANSAXLE GEAR SHIFT MODULE
OE
RC-CP06-14
3/1/2014
Safety Recall P42 - Knee AirBag Module
OE
RC-P42-14
9/1/2014
SAFETY RECALL P42 - KNEE AIRBAG MODULE
OE
RC-CP42-14
9/1/2014
2015 Fiat 500 Recalls
Source Type
TSB #
Issue Date
Type
OE​
RC-P42-14​
9/1/2014​
OE​
RC-CP42-14​
9/1/2014​
2012 TSB (Includes recalls)
Technical Service Bulletin (TSB) DescriptionSource TypeTSB #Issue DateType
Vehicles Shipped From Plant Without Navigation CradleOE08-050-118/12/2011Technical, Warranty, Labor
Front Seat Easy Entry Handle InoperableOE23-032-11REV.A8/27/2011Technical
Vehicle Received Without Blue Key Code CardOE23-026-116/25/2011Technical
Seat Fabric Spotting And/Or RingingOE23-020-116/2/2011Technical
Flash: MIL Illumination Or Chime With Message In Cluster, Coolant...OE18-013-11 REV. A6/29/2011Technical, Warranty, Labor
Reconditioned Wheel UsageOE31-005-1111/10/2011Collision Bulletin
Repair Parts Used For Structural RepairsOE31-002-1111/10/2011Technical
Replacement Seat Covers And Seat Cover RepairsOE31-004-1111/10/2011Technical
Salvaged Airbags Or Other Salvaged Restraint System Component Usa...OE31-003-1111/10/2011Technical
Use of Heat To Straighten Damaged ComponentsOE31-001-1111/10/2011Technical
Vehicle Theft Alarm (VTA) InoperativeOE08-063-1112/1/2011Technical, Warranty, Labor
Flash: Instrument Cluster Lock UpOE08-059-1110/25/2011Technical, Warranty, Labor
Diagnostic Link Connector - DLC, Cover Must Be Removed From U.S. ...OE08-056-1110/5/2011Technical, Recall, DealerNotification, Warranty, Labor
Click And/Or Clunk Near A-Pillar While Opening DoorsOE23-038-11 REV. A12/2/2011Technical, Recall, DealerNotification, Warranty
Water Leak At Rear Window And/Or Damp Carpet In TrunkOE23-037-119/14/2011Technical
Light To Moderate Paint Surface Imperfections On Factory Applied ...OE23-003-122/7/2012Technical
Safety Certification and Tire Pressure Label Replacement Guidelin...OE31-002-122/2/2012Technical
Wheel Bearing and Hub Replacement/Inspection Guidelines During Co...OE31-001-121/11/2012Technical
Emissions Recall M03 - Diagnostic Link Connector CoverOERC-M03-123/1/2012Technical, Recall, DealerNotification, Warranty, Labor
Vehicle Theft Alarm (VTA) InoperativeOE08-010-122/14/2012Technical, Warranty, Labor
Flash: Express Down Window Function Stops With Window Part Way Do...OE08-065-1112/22/2011Technical, Warranty, Labor
Transit Film RemovalOE23-010-123/16/2012Technical
Gap Between C-Pillar Trim And HeadlinerOE23-005-121/25/2012Technical, Warranty, Labor
Click And/Or Clunk Near A-Pillar While Opening DoorsOE23-002-121/10/2012Technical
Fiat Customer InitiativeOE26-001-123/20/2012Technical
Customer Satisfaction Notification M02 - Sunroof Hex WrenchOERC-M02-123/1/2012Technical, DealerNotification, Warranty, Labor
Safety Recall L39 - Brake Fluid Contamination - STOP SALE ORDEROERC-L39-122/1/2012Technical, Recall, Warranty, Labor
Customer Satisfaction Notification L36 - Wheel Lug Nut WrenchOERC-L36-1112/1/2011Technical, DealerNotification, Warranty, Labor
Customer Satisfaction Notification M02 - Sunroof Hex WrenchOERC-IM02-123/1/2012Technical, DealerNotification, Warranty, Labor
Customer Satisfaction Notification L36 - Wheel Lug Nut WrenchOERC-IL36-1112/1/2011Technical, DealerNotification
CUSTOMER SATISFACTION NOTIFICATION M02 - SUNROOF HEX WRENCHOERC-CM02-123/9/2012Technical, DealerNotification, Warranty, Labor
SAFETY RECALL L39 - CONTAMINATED BRAKE FLUIDOERC-CL39-123/6/2012Technical, Recall, DealerNotification, Warranty, Labor
CUSTOMER SATISFACTION NOTIFICATION L36 - WHEEL LUG NUT WRENCHOERC-CL36-1112/16/2011Technical, DealerNotification
Flash: MIL Illumination Or Cancel Cruise Control Bump Feeling Or ...OE18-014-123/21/2012Technical, Warranty, Labor
Unable To Add Engine OilOE09-003-1112/21/2011Technical, Warranty, Labor
Welded Sheet Metal Repairs and ReplacementsOE31-007-128/14/2012Technical
Do Not Apply Corrosion Protection On SMC (Plastic) PanelsOE31-005-128/3/2012Technical
Engine Oil Consumption GuidelineOE09-001-126/27/2012Technical
Fluid Flushing RequirementsOE26-004-126/6/2012Technical
Front Fascia Repair When License Plate Bracket Has Been RemovedOE31-004-127/26/2012Technical
Adaptive Cruise Control (ACC) Module Sensor and Bracket Guideline...OE31-003-123/30/2012Technical
Intermittent Horn Actuation Or Sticking Once ActuatedOE08-036-125/18/2012Technical, Warranty, Labor
Water On Top Of Engine CoverOE23-013-12 REV. A5/25/2012Technical, Warranty, Labor
Flash: MIL Illumination And/Or Engine KnockOE18-016-126/26/2012Technical, Warranty, Labor
MIL Illumination For P1CEA - Boost Side EVAP Purge System Perform...OE18-018-126/8/2012Technical, Warranty, Labor
Tom Tom Message Searching For GPS Or Can't Pair With Blue And MeOE08-062-1211/29/2012Technical, Warranty, Labor
Flash: Convertible Decklid Will Not Close And Ajar Indicator Lamp...OE08-054-129/21/2012Technical
Liftgate Emblem Paint PeelingOE23-035-1212/13/2012Technical, Warranty, Labor
Fiat Customer InitiativeOE26-001-12 REV. A9/8/2012Technical
Customer Satisfaction Notification M29 - WindscreenOERC-M29-1212/1/2012Technical, Recall, Warranty, Labor
Customer Satisfaction Notification M32 - Reprogram Powertrain Con...OERC-M32-129/1/2012Technical, Recall, Warranty, Labor
Customer Satisfaction Notification M29 - WindscreenOERC-IM29-1212/1/2012Technical, Warranty, Labor
Customer Satisfaction Notification M32 - Reprogram Powertrain Con...OERC-IM32-129/1/2012Technical, Recall, Warranty, Labor
CUSTOMER SATISFACTION NOTIFICATION M29 - WINDSCREENOERC-CM29-1212/1/2012Technical, Recall, Warranty, Labor
CUSTOMER SATISFACTION NOTIFICATION M32 -REPROGRAM THE POWERTRAIN ...OERC-CM32-129/1/2012Technical, Recall, Warranty, Labor
Customer Satisfaction Notification M20 - Engine Coolant Hot Bottl...OERC-IM20-1210/1/2012Technical, Warranty, Labor
Customer Satisfaction Notification M20 - Engine Coolant Hot Bottl...OERC-M20-1210/1/2012Technical, Recall, Warranty, Labor
CUSTOMER SATISFACTION NOTIFICATION M20 - ENGINE COOLANT HOT BOTTL...OERC-CM20-1210/1/2012Technical, Recall, Warranty, Labor
Gasoline Engine Diagnostic Inspection ProcedureOE09-001-132/6/2013Technical, Warranty, Labor
Blending Clearcoat During The Refinish ProcessOE31-002-131/31/2013Technical
Overspray RemovalOE31-001-131/11/2013Technical
Cold Weather Noise From Front End Over BumpsOE02-002-134/4/2013Technical, Warranty, Labor
Chrome Top Cap On Shift Knob is LooseOE21-002-134/3/2013Technical, Warranty, Labor
Customer Satisfaction Notification N15 - Starter Motor Mounting B...OERC-N15-134/1/2013Technical, Recall, Warranty, Labor
Customer Satisfaction Notification N15 - Starter Motor Mounting B...OERC-IN15-134/1/2013Technical, Recall, Warranty, Labor
CUSTOMER SATISFACTION NOTIFICATION N15 - STARTER MOTOR MOUNTING B...OERC-CN15-134/1/2013Technical, Recall, Warranty, Labor
B-Pillar Body Creak NoiseOE23-034-1310/3/2013Technical, Warranty, Labor
Side Door Glass Is Inoperable, Binds And/Or Moves SlowOE23-029-138/6/2013Technical, Warranty, Labor
Front And/Or Rear Emblems Bubbling And/Or FadingOE23-023-136/29/2013Technical, Warranty, Labor
Tire Flat Spotting Identification, Prevention and ResolutionOE22-002-14 REV. A4/15/2014Technical, Information
Steering Wheel Vibration at Highway SpeedsOE22-001-142/19/2014Technical, Warranty
Flash: Clock In The Cluster Gains Or Loses TimeOE08-012-14 REV. A4/23/2014Technical, Warranty, Labor
Rear Axle Alignment ShimsOE17-001-146/24/2014
Flash: Engine Crank, No Start and/or Malfunction Indicator Lamp (...OE18-007-14 REV. A8/14/2014Technical, Warranty, Labor
Rear Window Washer Nozzle Drips And/Or Leaks While DrivingOE23-015-146/25/2014Technical, Warranty, Labor
Flash: Clock In The Cluster Gains TimeOE08-012-141/31/2014Technical, Warranty, Labor
Flash: Engine Crank, No Start and/or Malfunction Indicator Lamp (...OE18-007-142/11/2014Technical, Warranty, Labor
Front Suspension Clunk Noise While Making Left And Right TurnsOE02-006-149/26/2014Technical, Warranty, Labor
Flash:1.4L Diagnostic And System ImprovementsOE18-007-14 REV. B10/18/2014Technical, Warranty, Labor
Flash:1.4L Diagnostic And System ImprovementsOE18-027-154/7/2015Technical, Warranty, Labor
Clunking Noise From The Steering Column While Turning The Steerin...OE19-002-154/8/2015Technical, Warranty, Labor
Flash:1.4L Diagnostic And System ImprovementsOE18-027-15 REV. A4/18/2015Technical, Warranty, Labor
2013 Fiat 500 TSB (Includes recalls)
Source Type
TSB #
Issue Date
Type
OE
09-001-13
2/6/2013
OE
31-002-13
1/31/2013
Technical
Overspray Removal
OE
31-001-13
1/11/2013
Technical
OE
02-002-13
4/4/2013
Loss Of Communications With Convergence Telematics Module (CTM)
OE
08-015-13
3/15/2013
OE
RC-N09-13
2/1/2013
OE
RC-CN09-13
2/1/2013
Flash: MIL Illumination P0456- Evap System Small Leak or P0128- T...
OE
18-040-13
9/12/2013
Flash: MIL Illumination P1CEA- Boost Side Evap Purge System Perfo...
OE
18-028-13 REV. A
9/6/2013
OE
23-034-13
10/3/2013
OE
23-029-13
8/6/2013
OE
23-023-13
6/29/2013
Customer Satisfaction Notification N03 - Tire Pressure Monitor & ...
OE
RC-N03-13
9/1/2013
CUSTOMER SATISFACTION NOTIFICATION N03 - TIRE PRESSURE MONITOR & ...
OE
RC-CN03-13
9/1/2013
Technical, DealerNotification, Information, Warranty, Labor
OE
RC-N51-13
8/1/2013
NHJ Heated Mirror Inoperative
OE
08-085-13
11/7/2013
Flash: Energy Usage Display Enhancements
OE
08-083-13
10/24/2013
OE
22-002-14 REV. A
4/15/2014
OE
22-001-14
2/19/2014
Technical, Warranty
Flash: Vehicle Enhancements
OE
08-048-14 REV. A
5/31/2014
Flash: Enable Shift Up Indicator
OE
08-014-14
2/5/2014
OE
17-001-14
6/24/2014
Safety Recall P23 - Power Inverter Module
OE
RC-IP23-14
8/1/2014
OE
RC-P23-14
8/1/2014
OE
18-007-14 REV. A
8/14/2014
OE
23-015-14
6/25/2014
OE
02-006-14
9/26/2014
OE
18-007-14 REV. B
10/18/2014
OE
08-048-14 REV. B
10/30/2014
Convergence Telematics Module (CTM) Software Enhancements
OE
08-101-14
11/22/2014
FLASH: Battery Electric Vehicle, Multiple System Enhancements
OE
08-004-15
1/9/2015
OE
18-027-15
4/7/2015
OE
19-002-15
4/8/2015
OE
08-004-15 REV. A
4/13/2015
OE
18-027-15 REV. A
4/18/2015
2014 Fiat 500 TSB
Inludes recalls as well - forgot to put it in the title!
2014 FIAT 500
Source Type
TSB #
Issue Date
Type
Exterior Lamp Condensation And Fogging
OE
08-086-13
10/30/2013
Technical
OE
08-048-14 REV. A
5/31/2014
OE
08-048-14
5/15/2014
Removal Of Beats Audio System
OE
08-057-14
7/17/2014
Technical
Instrument Panel 500 Nameplate Not Fully Seated
OE
23-025-14
9/24/2014
OE
02-006-14
9/26/2014
OE
08-048-14 REV. B
10/30/2014
OE
08-101-14
11/22/2014
Flash: MIL Illumination, P0141 Oxygen Sensor 1/2 Heater Performan...
OE
18-069-14
11/26/2014
OE
08-004-15
1/9/2015
OE
18-010-15
1/23/2015
OE
19-002-15
4/8/2015
OE
18-010-15 REV. A
4/13/2015
OE
08-004-15 REV. A
42107
2014 FIAT 500L
Source Type
TSB #
Issue Date
Type
Flash: MIL Illumination - DTC P0571
OE
21-008-13
8/16/2013
RA3 Soft Touch SAT Button Does Not Work
OE
08-055-13
7/30/2013
Navigation Map Activation RA3 Radio
OE
08-044-13
6/5/2013
Flash: MIL Illumination P113D- O2 Sensor 1/1 Slow Response
OE
18-033-13 REV. A
10/2/2013
Transmission Temperature Warning Lamp ON
OE
18-030-13
7/23/2013
OE
08-086-13
10/30/2013
Technical
Fog Lamps Stay On With High Beams
OE
08-052-14
6/10/2014
Odometer Flashing And B10AA-4A- Check Configuration Failed - Inco...
OE
08-051-14
6/5/2014
Flash: RA3 Radio Software Enhancements
OE
08-031-14
4/8/2014
Diagnostic: Radio And Navigation Unit Updates
OE
08-034-14
3/20/2014
Flash: Improved Engine Crank Times And Engine Performance Enhance...
OE
18-017-14
3/27/2014
Flash: Transmission Control Module Body Control Module And Instr...
OE
18-020-14
3/19/2014
OE
22-002-14 REV. A
4/15/2014
OE
22-001-14
2/19/2014
Technical, Warranty
OE
RC-P06-14
3/1/2014
Recall
OE
RC-CP06-14
3/1/2014
OE
RC-P42-14
9/1/2014
OE
RC-CP42-14
9/1/2014
Flash: Oil Pressure Indicator Flashes When The Change Engine Oil ...
OE
08-070-14
8/22/2014
OE
18-017-14
3/12/2014
OE
08-031-14
3/15/2014
OE
18-017-14
3/17/2014
Flash: 1.4L Powertrain Diagnostic And System Improvements
OE
18-033-15
4/16/2015
2015 Fiat 500 TSB (includes recalls)
2015 FIAT 500
Source Type
TSB #
Issue Date
Type
OE
02-006-14
9/26/2014
OE
18-058-14
10/30/2014
OE
08-103-14
11/26/2014
OE
08-103-14 REV. A
12/10/2014
OE
18-058-14 REV. A
12/23/2014
OE
08-004-15
1/9/2015
OE
18-010-15
1/23/2015
OE
19-002-15
4/8/2015
OE
18-010-15 REV. A
4/13/2015
OE
08-004-15 REV. A
4/13/2015
Inoperative Blue And Me Steering Wheel Button
OE
08-049-15
5/5/2015
2015 FIAT 500L
Source Type
TSB #
Issue Date
Type
OE
RC-P42-14
9/1/2014
OE
RC-CP42-14
9/1/2014
Flash: 1.4L Diagnostic And System Improvements
OE
18-032-15
4/16/2015
OE
18-032-15 REV. A
4/29/2015
Flash: Transmission Shift And Drivability Enhancements
OE
21-031-15
5/9/2015
P06 Recall
I have 2014 L EZ that had the recall performed in 2014. The problem is that it still has the issue of sometimes not being able to shift out of park into drive or reverse. This has been an ongoing issue since we purchased it and the fiat service station has never been able to duplicate the issue. We have had to have it towed to the dealer when we couldn’t shift in traffic in the middle of a street. They told us it was the battery and replaced it. Now my Fiat is out of warranty and sitting out in front of my house and can’t get out of park. The recall said some cars would have to have the shift module replaced. I’m tired of taking it in only for them to charge me for some obscure other issue like changing the tire or battery and never resolving this issue. What the crap else can I do?
1 - 15 of 15 Posts
