Kiesling is of course correct that our migrating % gauges have no effect on actual mi/kWh. My response was to twinturboz' 100 mile range, but now I'm wondering about the car's mi/kWh display. I wonder how the car calculates mi/kWh. If it goes by how many percent is used per mile, then it could be just as (in)accurate as the % gauge.
If so, then both of twinturboz' numbers would read higher than cars with more than his tiny 2% gauge discrepancy (I assume that's at the low end, since the middle & top are much different from that on mine).
Also, speed & 1-way hills are two of the 3 biggest factors for range, so it's definitely an advantage to have even a very slight decline on the way to work, & very slightly slower speed on the way home.
In auto maintenance training I was taught that toe alignment setting is intended to yield zero toe while driving. A very slight toe-in setting at rest is used if needed to prevent toe-out. It compensates for flex of the suspension components under the load of tire's rolling resistance & slight brake pad grazing pushing the wheels aft.
Either way, after driving a couple thousand miles even with very slightly non-zero toe-at-speed, you can usually feel slight "feathering" of the tread: Hold your hand flat as if making a hand-print, & slide it side-to-side across the top of the tire. If you feel even a very slight difference between sliding in & sliding out, your tires are not running at zero toe while driving, regardless of how they are at rest.
