Keep in mind that when it's as "chilly" as the middle of winter can be there, in the US Midwest, 500e range can drop all the way to only the US average daily round-trip commute of about 40 miles, & to fully recharge from the OEM cord plugged into a stove or dryer outlet would take 8 hours of sleep PLUS an hour dinner AND an hour breakfast:Thanks; looks like a go in flat, chilly, lakeside IL.
Thanks for your comment in the inflator kit; will pass that along.Keep in mind that when it's as "chilly" as the middle of winter can be there, in the US Midwest, 500e range can drop all the way to only the US average daily round-trip commute of about 40 miles, & to fully recharge from the OEM cord plugged into a stove or dryer outlet would take 8 hours of sleep PLUS an hour dinner AND an hour breakfast:
The OEM cord is level 1 when plugged into a 120 volt outlet. In cold conditions, it will take longer to charge on level 1 or level 2 since energy from the charger will go into conditioning the battery. I'm not sure how much time it will add in cold conditions. I've read if you are preheating the cabin + battery conditioning, the Level 2 power doesn't have much left for actual charging. On level 1 you will actually lose power.Thanks for your comment in the inflator kit; will pass that along.
I’ll be doing L2 charging at a public lot nearby; doesn’t the battery thermal system try to warm it then, to keep charge times reasonable?
Maybe not quite that bad. Found a useful chart of range% vs Temp, and average lows in Jan and Feb are 25F, so I should see 75% range, optimistically.That's all true, but my point was that cold weather uses more of the battery per mile, so in the winter it takes longer to recharge the same driving distance as in the summer...:
Let's say you get:
Then driving 40 miles:
- 4 miles per kWh in the summer & a total range of 80 miles.
- 2 miles per kWh in the winter & a total range of 40 miles.
- In summer it uses only 50%, so a recharge is about 2 hours on full 6.6kW L2*
- In winter it uses 100%, so a recharge takes about 4 hours on full L2, PLUS as @Kiesling noted, a bit more time to heat up the battery first unless it's still warm from driving.
Afraid that seller has some wiggle room here, as that link mentions the tire inflator kit as “if equipped”. Even so, how much allowance might I ask for, since it is missing?The 500e definitely came standard with a tire inflator kit (12V compressor & aerosol sealant) as shown* in the 2017 manual page 225 (pdf 227). Click for link.
